Full Version: Buffering problems
Hi there - I'm currently using Kodi via my MX2 android tv box dual core 4.2 jelly bean. I've been experiencing really bad buffering when streamin movies for which i usually use Genesis. Most of the time the audio is out of sync also and the audio offset doesn't seem to make any difference. I have done things already to combat the issue like zero the cache, clear packages & cache and advanced xml but nothing has changed. I'm on BT fibre optic 38mb/s download speeds and I'm connected via Ethernet direct to the Hub. I only really want to do 2 things which is stream off Genesis and watch live football via Sports Devl but am strugging to do either.
I don't really know what else to try as i'm very new to this, could it be in my internet settings or should i try a US VPN? SadSad
Here are to logs i've downloaded last night don't if they'll help:
Your debug xbmc.log: http://xbmclogs.com/show.php?id=421267
Your debug xbmc.old.log: http://xbmclogs.com/show.php?id=421268
I believe that both of the addons you are discussing are banned on this forum.
Sorry my mistake
