Full Version: Kodi crash right after start
Hi Everyone,
My problem is: 80-90% times i star Kodi after few seconds in full screen I see something like "blink" on interface, and it stops. In 10-20% after the blink Kodi will survive and I could use it without the problem.
I use Debian unstable and that problem was in every version of Kodi i had. Currently it is:
$ dpkg -l kodi
ii kodi 5:14.1-dmo3 all Kodi Media Center (full metapackage)
My laptop is: ASUS ux32vd, with intel and nvidia graphic card. When kodi is started with primus run i see this message in moment of "blink": primus: warning: timeout waiting for display worker
Its worth to notice that even when its is less posible to crash on primusrun, my laptop starts to be insanely hot so its not a solution.
cpu: Intel® Core™ i7-3517U CPU @ 1.90GHz
00:02.0 VGA compatible controller [0300]: Intel Corporation 3rd Gen Core processor Graphics Controller [8086:0166] (rev 09) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device [1043:1507]
Flags: bus master, fast devsel, latency 0, IRQ 48
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
Kernel driver in use: i915
Here is my crashlog:
http://pastebin.com/vQGTHbBd
Thanks in advance!
Crashes in the gpu driver:
Quote:0x00007f1d1279c8fd in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
Most likely a bug in mesa -> bugs.freedesktop.org
