2015-02-11, 12:14
2015-02-11, 13:16
sure, but it requires a bit of skinning knowledge to do so.
1) put the font in the skin.transparency/fonts folder
2) if you only want to use this font in specific views (instead of allthroughout the skin)
you need to add a <font> defenition for each size you want to use to skin.transparency/720p/Font.xml
make sure the names you use are unique.
3) Open View-List.xml and DialogVideoInfo.xml and replace the current <font> entries with the ones you've just created.
2015-02-11, 20:23
Thanks!!
I'm using openelec and the folders are read only =/
