Hi there - updated kodi to current git-version (today), and also updated pvr-addons from opdenkamp (git pull)
When activating Live-TV i get a crash-log and core - dump
can anyone help?
Crashlog can be found
here
Did you use the Helix branch of updated pvr-addons from opdenkamp, because master branch crashes kodi 14.1, which I also saw yesterday
I cloned branch helix - which works so far - but that shows version 1.9.22 which has
this epg-bug
Thanks - but precompiled is not an option for me
Compiled and works (as expected) - need to check if the EPG-Issue is gone (but i assume it is) - the interesting question remains:
why it is crashing and what to do?
(2015-02-12, 18:39)magicamun Wrote: [ -> ]why it is crashing and what to do?
you compiled opdenkamp/master and used with Helix, don't you? those versions are not compatible.
(2015-02-12, 20:02)FernetMenta Wrote: [ -> ] (2015-02-12, 18:39)magicamun Wrote: [ -> ]why it is crashing and what to do?
Good point - will Master work with 14.2? what basically differs in master from Helix?
(2015-02-12, 20:35)magicamun Wrote: [ -> ]Good point - will Master work with 14.2? what basically differs in master from Helix?
There are API/ABI changes from 14.x to 15x. Addons are not backwards compatible. This means that master branch of addons is only compatible with master of Kodi. This is why there is a Helix branch in both repos.
