2 weeks ago my Disclose.TV add-on stopped playing any videos with "Error: Script Failed" Disclose.TV.
I already Deleted the "Plugin.video.Disclose.TV" file from my User\appdata\roaming\kodi\userdata\add-ondata folder,
Uninstalled Disclose.TV add-on.
Shut down Kodi.
Re- installed Disclose.tv add-on ....and still get the same "Error: Script Failed" Disclose.TV.
Thanks in advance.
I started having the same issue earlier this week. I get the message "Script Failed! : addon.py". This happens on my jailbroken ATV2 running XBMC, my Mac and Windows machine.
I have uninstalled and reinstalled.
Have you been able to resolve the issue?
No I have not, and it is good to hear you are experiencing it on (3) different OS"
the add-on was broken due to website changes.
I fixed the add-on and uploaded the fixed version (0.1.0) you should receive an update shortly.
regards,
sphere
danke schoen,
We are proud German Americans.
I'm no python developer but i use this plugin each day so I took a look...
There is a problem with the json from the site. when it tries to parse it in scraper.py.
this one liner fixes it...
response = response.replace("\n", ' ').replace("\r", ' ')
it goes in here...
@staticmethod
def __img(url):
return url.replace('135x76', '').split('?')[0]
def __get_json(self, url):
response = self.__get_url(url)
# here is where you put it
if not '"' in response:
response = response.replace('\'', '"')
return json.loads(response)
def __get_tree(self, url):
html = self.__get_url(url)
regards,
Ignore this, author has just fixed it
(2015-02-14, 19:50)roundyz Wrote: [ -> ]I'm no python developer but i use this plugin each day so I took a look...
You should have a look to my previous post, I already fixed the add-on but the kodi repos take some time to make the new version available.
Regarding your change itself,
I fixed it in a more robust way
I will close this thread because there is
already a thread for this plugin
