Full Version: Dependency not met + OpenElec 5.0.1 (Kodi 14.1)
I have an Raspberry Pi 2 where I have installed OpenElec 5.0.1 (Kodi 14.1). When I try to install the Amber theme I get "Dependency not met". I downloaded the latest amber source from github (master branch). What do I need to update?
I have updated first post with a location of 2 scripts Amber is using. Try to install them manually before installing skin and post your results.
http://forum.kodi.tv/showthread.php?tid=...pid1788195
Thank you!
It worked using this file: https://github.com/pecinko/skin.amber/ar...master.zip
Instead of this one: https://github.com/jester-xbmc/skin.amber
I guess that the first one is the official repo that I should use right?
