2015-02-12, 23:00
Hello -
I hope I'm posting in the right place.....
I have used XBMC for a couple of years, and have never had a significant problem with it until now. I am using KODI 14.0, along with a Logitech Harmony 650 remote control, and an Adesso ARC-1100 IR receiver for my PC. A few days ago, KODI quit receiving most commands from the remote. The directional arrows still work, and the center "select" button still works, but just about every other command does not. For example, I can use the remote to select "Movies", navigate to the movie I want with the arrow keys, and select it. The movie will start playing, no problem. However, if I try to stop, pause, skip a chapter, or anything else with the buttons on the Harmony, I get no response from KODI. If I use the Adesso remote that came with the receiver, I can navigate to the controls onscreen, but I can't get the individual stop, pause, etc buttons on the Adesso remote to work, either.
I've reinstalled KODI, and I've re-synced the Harmony remote with no change. I have another, almost identical setup that works fine. Same model of Addeso IR receiver, same Harmony 650 remote. So I attempted to use those remotes on the system that is not working properly, and they didn't work there, either.
Any ideas?
Dave
Any ideas?
Dave
