2015-04-13, 23:27
(2015-04-13, 20:21)Helioy Wrote: [ -> ]Just wanted to say that MilkDrop works perfectly
Thanks. You can also try MilkDrop2 from here https://github.com/afedchin/Milkdrop2-XBMC/releases
(2015-02-13, 16:43)da-anda Wrote: [ -> ]Having a crash on startup "unable to create GUI"
- Windows 8.1 Pro 64-Bit (6.3, Build 9600) with DirectX 11
- Intel Core i5
- ATI Mobility Radeon HD 4300/4500 Series and "latest" (beta) drivers (v8.970.100.1100)
- my debug log
(2015-05-02, 14:39)Brainiarc7 Wrote: [ -> ](2015-02-13, 16:43)da-anda Wrote: [ -> ]Having a crash on startup "unable to create GUI"
- Intel Core i5
- my debug log
Hey man,
You have a DirectX 10.1 GPU.
This build requires a DirectX 11 GPU. Older GPUs are not supported.
Compatible GPUs (By Vendor) are:
1. AMD Radeon HD 5000 series and above.
2. NVIDIA Fermi (GTX 400) and above.
3. Intel IvyBridge HD Graphics (HD 4000+ ) and above. SandyBridge and older iterations are not supported.
Regards,
Brainiarc7
- Intel Core i5
- my debug log
(2015-05-02, 19:13)Brainiarc7 Wrote: [ -> ](2015-02-13, 16:43)da-anda Wrote: [ -> ]Having a crash on startup "unable to create GUI"
- Intel Core i5
- my debug log
Sorry, your hardware is NOT DirectX 11 capable.
On AMD, Only HD 5000+ GPUs are supported.
AMD Radeon HD 4000 GPUs are capped at DirectX 10.1.
(2015-05-02, 14:39)Brainiarc7 Wrote: [ -> ]Hey man,DirectX11 application can run on DirectX9-capable hardware with limited features. we don't use DX11/10 specific features like tesselation or geometric shaders. So, DirectX 11 version of Kodi works as well with DirectX9-capable hardware as with DX11-capable hardware.
(2015-05-02, 15:27)Brainiarc7 Wrote: [ -> ]Here are the results on testing the DirectX 11 build:Thank you for your feedback.
