2015-05-31, 17:04
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
2015-05-31, 17:34
(2015-05-31, 17:03)afedchin Wrote: [ -> ]1. Thanks. I'll take a look at this.
2. You have 100% load of both CPU cores this causes GUI lags.
1. Thank you
2. That's the difference between this version and the nightly verisons, it sticks at 50fps or 60fps throughout with CPU at 5-10%. That's why I mentioned it
Edit: fritsch beat me to it.
2015-05-31, 20:07
@Piers,
One more qualification. dx9 version (nightly verisons) sticks at 50fps or 60fps whereas dx11 has a performance like at screenshots above. I understand you correctly?
2015-05-31, 21:42
2015-05-31, 21:57
Hardware: Windows 10 64bit Build 10074 and 10130, EVGA GeForce GTX 780 SC (03G-P4-2783-KR), Nvidia Driver 352.82, Monitors ASUS PB287Q @ 3840x2160 60Hz (DisplayPort) 150% scaling Dell 2001FP @ 1600*1200 60Hz (DVI-D) 100% scaling
Debug Logs: http://goo.gl/gey5kg "row 776 12:10:47 T:7764", http://goo.gl/YQbvzE "row 763 12:32:45 T:6396"
KODI Versions 14.2, 15.1 beta 1, DX11 version 20150503-b22fc9b, 20150530-bd9c482
Description: Changing from Full screen #1 to Full screen #2 changes to a small window on screen #1
Screenshot: https://www.dropbox.com/s/9ya1c90xnhhvr7...p.jpg?dl=0
How to reproduce: Change Full screen #1 to Full screen #2
Initial post: http://forum.kodi.tv/showthread.php?tid=228237
2015-05-31, 23:05
@Gamblah
Please try reproduce the issue without scaling. Do you have this on Win10 only or same issue occurs on other versions of Windows?
2015-06-01, 00:56
@afedchin
You found it.
I did some more testing with scaling.
Primary 100% Secondary 100% = Working fine on both
Primary 125% Secondary 100% = Full screen on both monitors but task bar showing on top of Kodi if activated.
Primary 125% Secondary 125% = Working fine on both
Primary 150% Secondary 100% = Messed up setting
Primary 150% Secondary 125% - Full screen on both monitors but task bar showing on top of Kodi if activated.
Primary 150% Secondary 150% - Working fine on both
Unfortunately I don't have any win 8 or 8.1 installations at this time but will see if I can do a installation of one of my drives to test scaling out.
Windows 7 worked fine with this monitor setup but had to run at 150% on both monitors as it did not support independent scaling.
For Windows 10 at this time I will run primary at 150% and secondary at 125% and live with the "larger" setting on the secondary monitor.
You found it.
2015-06-01, 15:29
@Piers
As I could see you are using xperience1080 skin. Could you enable RSS Feed and try again? Let's me explain. RSS Feed causes update GUI at max rate because it updates GUI every frame. Whereas for lack of GUI updates causes dropping FPS. Current nighties has same behavior. This is especially evident on the last screen because there are no GUI updates.
@Gamblah
Thank you for your diggings. I'll take a look at this when I'll have time enough.
@Gamblah
2015-06-02, 14:25
New build:
Fixed:
Download link at the first post.
There is new screensaver addon Shadertoy Screensavers especially developed for dx11 version and can be downloaded at https://github.com/afedchin/screensaver....y/releases
@Piers
Please, test the new build to color space issue?
Fixed:
- Fixed segfault if movie file contains SSA/ASS subtitles.
- Try to fix color space issue with dxva.
- Rebased to current master to include fixes and improvements.
@Piers
2015-06-02, 15:31
(2015-06-02, 14:25)afedchin Wrote: [ -> ]New build:
Fixed:
@Piers
@afedchin - Will do. Are you ever on IRC?
2015-06-02, 18:17
I played content with the June 2 build and compared it to the latest master nightly. Colors were identical on my Nvidia GTX750ti. Renderer was set to "auto" and DXVA2 was enabled.
General performance seems to be as good as the main master for me. If there is something specifc that needs testing let me know. I'll be happy to do it.
2015-06-02, 20:00
@kricker
Thanks for helping. It would be nice if you test the match refresh rate with video setting in true fullscreen mode.especially for 23.967 fps.
2015-06-02, 20:21
I did test in true fullscreen, but to be honest, I am not sure exactly how match refresh is supposed to work. I did play some 23.976 fps when testing the colors. The video info window showed it was playing at 23.976 (actually 23.81 to 24.04 or somewhere in between at times), but I do not know how to check my TV/monitor to see if it really switches to that. When I use the setting "Adjust display refresh rate", it doesn't look any different than when I don't use it. Same with "Sync playback to display."
2015-06-03, 18:02
On my Dell Inspiron Duo it crashes with 2 June build
Zip with crashlogs+dump+Debug Log
https://www.dropbox.com/s/v6hkafalqr5um8...h.zip?dl=0
https://www.dropbox.com/s/a8oy1wwdj9dalf...g.log?dl=0
It just keeps creating the dmp files and i have no picture on start
Edit:
master build starts without problems
Edit:
