Full Version: Windows DirectX 11 upgrade test thread
Jule 22 build was updated. Download link at the first post.
In a Window and Fullscreen-Window its working now.
In a real Fullscreen it still Crashing.
From Intel to AMD Stacktrace, Log and Dump
From AMD to Intel Stacktrace, Log and Dump
Please continue dx12 related discussion here http://forum.kodi.tv/showthread.php?tid=232831
@nille02,
Please test this build + pdb.
Its not crashing but he dont switch the monitor. If i restart kodi, he shows then on the other display
http://pastebin.com/hyZMws4E
(2015-07-19, 22:12)afedchin Wrote: [ -> ]It same in most cases but not in all. During work on dx11 I've found and got rid of a several bottle necks, made a several improvements and of course added usage new features of DX11, such as deferred rendering.
Nice.. Are there some benchmarks/measurements available? Kodi dx9 vs kodi dx11.
(2015-07-22, 18:15)nille02 Wrote: [ -> ]Its not crashing but he dont switch the monitor. If i restart kodi, he shows then on the other display
Thank you for testing this. Yes it's a know issue. Will be fixed in Kodi 16.x.
(2015-07-22, 19:36)Robotica Wrote: [ -> ]Nice.. Are there some benchmarks/measurements available? Kodi dx9 vs kodi dx11.
Work still in progress. But even when work is completed this is a another huge work to make a comparison. If someone wants to do that, feel free to do.
(2015-07-22, 20:06)afedchin Wrote: [ -> ]
I guess GUI isn't really interesting to stress-test; only power consumption in some different scenario's (idle, Kodi GUI, visuals, screensaver). Hardware based decoding (D3D11 or DXVA) could be tested by comparing CPU usage and power draw between both, right?
Would that cover what you have in mind?
tested the build from today with amd deinterlacing patch. but deinterlacing didnt work for me (deinterlacing method is greyed out and there is no deinterlascing)
debug log:
http://pastebin.com/Vnx7ZqKj
Deinterlacing method selected by the driver now. it is normal if it is greyed in OSD setting.
yes, i have seen in debug log that now are different dxva deinterlacing methods available.
but there was definitely no deinterlacing. i can very clearly see this.
I guess you enabled deinterlacing via video menu? So it did not work for you with deinterlacing auto/on?
That's, strange. I have access to legacy AMD hardware now that does not even support D3D11 video. I will check once again at home on Sunday.
yes there is no deinterlacing, i can see this on live-tv picture. yes, i activate this within video menu. i also switched the settings "always on/auto/off" but this makes no difference.
I was asked to submit this by fritsch in the IRC channel. using july 23rd, 2015 test windows build of v15 with directx 11. anytime kodi window loses focus, as soon as you switch, it will completely freeze for 10-15 seconds every time. Attached is pastebin to Debug Log. thanks
http://pastebin.com/V9ySUPPX
I just checked deinterlacing on Radeon HD 6570 and Catalyst 14.12 (Omega) and it worked just fine with both builds (mine and afedchin's vanilla). Debug log is same as yours. I used a local file (I do not use PVR). Judging by the image it looked as VA deinterlacing (definitely not like bob).
Would you please post screenshots from DXVA Checker Processor Device / Direct3D 11 Processor Caps and Rate Conversion Caps tabs?
These are mine:
http://postimg.org/image/t3dq6fhuh/
http://postimg.org/image/lyx5ejr9j/
Might hopefully provide some clues why deinterlacing is not working for you.
