So basically that's the end of decent Win7 support for Kodi?
@afedchin:
i had the settings in driver as describet in your link. then it seems its a driver (dxva) problem, because, as i describet, i get different results if i turn on/off dxva2 with one and the same driver-setting. (but i use win 8.1)
(2015-12-21, 12:09)afedchin Wrote: [ -> ] (2015-12-21, 11:54)bossanova808 Wrote: [ -> ]So basically that's the end of decent Win7 support for Kodi?
why?
...because inaccurate video levels on a variety of hardware is a pretty fundamental problem, no?
You've got reports on nvidia, Intel and amd above...
(2015-12-21, 12:33)bossanova808 Wrote: [ -> ] (2015-12-21, 12:09)afedchin Wrote: [ -> ] (2015-12-21, 11:54)bossanova808 Wrote: [ -> ]So basically that's the end of decent Win7 support for Kodi?
why?
You missed the fact that it's also on Win10
afedchin
Good afternoon,
when I execute the tutorial, it crashs, I see a error panel with the text Creating devide failed
crown08
Seems your drivers is corrupt or not properly supports dual graphics for DirectX11 applications.
Hi. I have a problem with Jarvis latest beta and limited range.
I have an htpc with windows 10 64bit.
My hardware is an E450 apu with HD 6230 gpu and Catalyst Driver 15.7.1.
The driver setting is set to rgb 4:4:4 (full range), kodi has enabled the 16-235 limited range option and the tv hdmi is set to limited.
With this settings I get black crushed. Using the
AVS HD 709 black clipping pattern I should see black clipping bars but I see all black.
This is only with dxva render and dxva2 acceleration enabled. With pixel shader and dxva2 disabled I get the correct bars.
Here's the log:
http://xbmclogs.com/pp07zfp3l
afedchin
Just tried that version (26th Dec).
AMD 6530D set to YCbCr 4:4:4 (and AMD reports 10 bit being sent to Denon X2100 Amp). Win 7 64 bit all current updated. AMD latest drivers 'Crimson'.
With hardware acceleration:
Kodi set to full range:
UI good,
Videos elevated blacks
Kodi set to limited range:
UI elevated blacks
Videos look like 'double' elevated blacks
Without hardware acceleration:
Results the same.
Debug log here:
https://dl.dropboxusercontent.com/u/1088...6thDec.log
Hope this helps!
20151226 version's black level: 0.022 fL, same as v15.2! I thought this wasn't possible with my setup. What's changed?
