(2016-02-27, 16:15)afedchin Wrote: [ -> ]@Ed76
only video output makes sense. please ignore any issues with GUI. So test shows again driver ignores application settings and outputs video as it decides. Please test all possible cases:
1. Driver full + Kodi full
2. Driver full + Kodi limited
3. Driver limited + Kodi full
4. Driver limited + Kodi limited.
ladies and gentlemen, here are the results
catalyst: pixel format: full rgb for all test
1) catalyst: force full range for video, kodi full range, result: video full range
2) catalyst: force full range for video, kodi limited range, result: video full range
3) catalyst: force limited range for video, kodi full range, result: video limited range
4) catalyst: force limited range for video, kodi limited range, result: video limited range
video output concerning black clipping testvideo: 3) = 4) = mpc-hc (madvr). because in 3) the color range of gui is also good i could live with option 3)
with this testversion i am able to get a correct color range (video + gui) with full rgb output. another big advantage for me (and maybe others) is: because of forcing limited range within catalyst drivers also other external players with no possibility to set color range (amazon/netflix-html5 player) have correct video color. (thats not possible with kodi 16 final/ "new method" for setting color range).
with kodi 16 final (untouched, without my shader replacement) i get following results:
1) video full range
2) strange, in testvideo i can see blinking lines 17-25, but between 2-16 nothing is blinking/flashing (also if i rise the brightness of tv to 100%)
3 ) video limited range (but gui full range)
4) video is much to bright
hope it helps you, 1000 thanks for all your work!
