yep in red/cyan i get broken gui and video
(2015-02-24, 20:38)m910q Wrote: [ -> ]Nothing changed.
Here's the log: Debug log
I've not seen in your log what you changed video setting to choose HQ scalers as I asked for.
(2015-02-24, 18:48)Martijn Wrote: [ -> ]yep in red/cyan i get broken gui and video
So, the dxva renderer doesn't support default backbuffer format as I expected. But why? And why drivers still report what format supported? Seems like drivers support it but cannot work with it. Strange.
Workaround which I implemented in current branch should solve the issue. Still need to determine which drivers has this issue because workaround causes an extra shader execution.
So I Did the test like you wanted, the video did not play back at first, but when I changed the window in some way be it going fullscreen/windowed or moving it around it started working.
Log:
http://pastebin.com/ALYcGvBD
(PS Holy crap man thats a gui bug from hell lol)
(2015-02-24, 03:13)poplap Wrote: [ -> ]So when I first open the OSD it has Bicubic selected and a blank screen, as I switch though the options they all work except DXVA and Auto (Bicubic works though so I think it might be a GUI bug but I am not sure).
(Same issue as Martijn)
It's the exact same for me.
Log with scale changing:
Debug log
Log was taken when starting from a working Bicubic scaling.
New build:
Fixed:
- Added workaround to fix dxva rendering on some systems.
- Fixed GUI in anaglyph stereo mode.
- Fixed overlay rendering.
- Rebased to current master to include current fixes.
Download link in the first post.
Works for me.
Did a clean install, everything seems fine.
Sure thing.
Here's a debug log for a clean install, just playing the file:
Debug log
So everything seems to work well, tested with the same advanvesettings and DXVA set as the render, as well as setting everything back to default settings. I will say when playing the 3D clip it is really slow to start (a second or two) and lags for a few frames before playing smoothly. I have never messed around with 3D movies so I'm not sure if this is normal.
Log with advancesettings + DXVA Render:
http://pastebin.com/GKMeGQ8j
Log Default settings:
http://pastebin.com/vgbVuafC
m910q
poplap
Thank you too. As for issue with 3D movie it is normal for this test movie with dxva decoder.
(2015-02-25, 21:51)thecYrus Wrote: [ -> ]drag & drop the kodi window from one GPU to another crashes it. (it's a 3 screens setup with 2 GPUs)
Neither your GeForce 210 or GeForce 9800 GT supports DirectX 11.
But I guess it could still be a bug in the feature detection.
i doubt that kodi requires DirectX 11 feature-level GPUs. Should work without problems on older versions as well. Actually it works quite good here on individual screens. It's just that the current build doesn't handle GPU "remove" events. (DXGI_ERROR_DEVICE_REMOVED)
