(2015-02-25, 21:51)thecYrus Wrote: [ -> ]drag & drop the kodi window from one GPU to another crashes it. (it's a 3 screens setup with 2 GPUs)
log: http://1drv.ms/1LEdiqP
crashlog: http://1drv.ms/1BVBfu3
stacktrace: http://1drv.ms/1BVBlBN
Thanks but your log is not a
Debug Log. Please enable debug logging then try to reproduce issue.
(2015-02-25, 22:22)thecYrus Wrote: [ -> ]It's just that the current build doesn't handle GPU "remove" events. (DXGI_ERROR_DEVICE_REMOVED)
It does but this scenario is not tested. I have no possibility to test it.
(2015-02-25, 23:01)afedchin Wrote: [ -> ] (2015-02-25, 21:51)thecYrus Wrote: [ -> ]drag & drop the kodi window from one GPU to another crashes it. (it's a 3 screens setup with 2 GPUs)
Thanks but your log is not a Debug Log. Please enable debug logging then try to reproduce issue.
yeah sorry, debug wasn't enabled anymore. file updated. (
http://1drv.ms/1LEdiqP)
22:15:22 T:9124 DEBUG: CWinEventsWin32::WndProc: window move event
22:15:22 T:9124 DEBUG: Previous line repeats 54 times.
22:15:22 T:9124 ERROR: CGUIFontTTFDX::CreateVertexBuffer - Failed to create vertex buffer.
22:15:22 T:9124 ERROR: Previous line repeats 3 times.
22:15:22 T:9124 DEBUG: CRenderSystemDX:
resentRenderImpl - device removed
22:15:22 T:9124 ERROR: DXGI_ERROR_DEVICE_REMOVED
New build:
Fixed:
- Fixed resurrection on device changing.
- GUIFontTTFDX: properly release buffers at destroying font.
Download link in the first post.
thecYrus
Please try reproduce issue with new build. Thanks.
(2015-02-26, 15:38)afedchin Wrote: [ -> ]New build:
Fixed:- Fixed resurrection on device changing.
@thecYrus
it works. No crash while changing the screen anymore. But it freezes for a couple of seconds. I've updated the logfile again. Maybe you can see something. But thanks anyway!
just found another thing. switching to fullscreen-mode (alt+enter on windows) moves kodi to the screen which is set as primary in windows. it doesn't stay on the screen where it's active.
Martijn
Strange. Nothing critical changed in this part. Does issue exist with prev build?
thecYrus
In your log device was changing three times within three seconds: from initial 9800GT to GF210 (at 19:14:27), then back to 9800GT (at 19:14:28), then again to GF210 (at 19:14:30). I know what Kodi freezes during recreating all resources but I can do nothing with this. DX11 implementation uses much more resources (textures, buffers, states) which require recreating after changing adapter.
Edit:
(2015-02-26, 20:32)thecYrus Wrote: [ -> ]just found another thing. switching to fullscreen-mode (alt+enter on windows) moves kodi to the screen which is set as primary in windows. it doesn't stay on the screen where it's active.
You can change monitor in fullscreen-mode in the Kodi settings.
Last one that worked was from 20th
Martijn
Can you try with current branch? If issue is resolved I'll publish new build.
Martijn,
Not all so good. I saw in your first log what the dxva not works in general (decoding and rendering). Please can you check what your video driver is WDDM1.2?
(2015-02-27, 08:37)afedchin Wrote: [ -> ]@Martijn,
If you can tell how, sure. Finding out seems a real bitch.
The win7 computer with NIVIA GTX275 using the \ key for switching fullscreen mode switches my screen to a lower res.
http://pastebin.com/jTJcicqk
CWinSystemWin32::SetFullScreen (windowed) on screen 0 with size 635x374, refresh 0.000000
Using new build from this morning
(2015-02-27, 19:23)Martijn Wrote: [ -> ] (2015-02-27, 08:37)afedchin Wrote: [ -> ]Please can you check what your video driver is WDDM1.2?
dxdiag.exe should be able to tell that. Check the second tab.
http://i.imgur.com/WfHNfwI.png (image is from Finnish version)
it's WDDM 1.1 (Seems like that's almost standaard for Win7).
