2015-02-13, 20:47
Using Pseudotv Live 0.5.8d. With xbmc 13.2 on android kit kat.
After any restart and launching Pseudotv Live, I get the message "autotuning initiated". Then a large "Please Wait" appears in the middle of the TV. Th th That's all folks. The xbmc on the minix neo x8-h android box is locked up. After 2 hours nothing happens. Must exit back to android home, kill the xbmc task, and restart xbmc. If I again select pseudotv live the same thing happens.
A review of the log shows no errors.
Checked for settings2.xml. The file does not exist ... Only settings.xml exists.
Any help here is much appreciated. If I knew how, I would limit the channels loaded.
If I knew how, I would reload a lower release of pseudotv live.
Heck, if I knew how I'd fix it without troubling anyone.
Sure hope some of you have some suggestions.
Dr Dan
Dr Dan
