Full Version: Kodi keeps crashing and returns to login screen
Pages: 1 2
I have an NUC setup with Kodi installed on Ubuntu 14.04
This setup was working perfectly fine, until today when I did a dist-upgrade on my box and after reboot, it keeps crashing and starting again for a few times and then comes back to the Ubuntu Login page, the only thing I have done is the upgrade and installed an Video addon, log file is attached here.
Log File: http://pastebin.com/iQxn5ZPR
I;m unable to parse the log file as needed
Quote:17:26:44 T:140701158909696 NOTICE: AxelProxy Downloader Starting - 127.0.0.1:45550
17:26:44 T:140701158909696 NOTICE: Press CTL break to stop.....
17:26:44 T:140701224326912 NOTICE: Invoking URL: http://api.yousee.tv/rest/tvguide/channels/format/json
17:26:44 T:140701937407744 NOTICE: 1Channel: Service: Installed Version: 2.5.55
17:26:44 T:140701937407744 NOTICE: 1Channel: Loading sqlite3 as DB engine
No support for you: Banned_add-ons (wiki)
thanks, atleast I know its the addons, funny part is I havent used that addon, I had downloaded xstream to stream starsports subscription
new Log File, removed the addons http://pastebin.com/xvSNHXPT
PS: Just for testing I moved .kodi to .kodi_bak and it started working like it is suppose to.
Had same problem whit my nuc. got fixed it now. 218478 (thread)
no such file in that directory for me
So far I have removed sources.xml, guisettings.xml, mediasources.xml, advancesettings.xml and still not working.
my library sits on mysql databse which is reachable and running.
And it wont start when logging in onto the Unity desktop too
Also I'm using intel linux display drivers. https://01.org/linuxgraphics/
(2015-02-15, 17:55)masinad Wrote: [ -> ]Also I'm using intel linux display drivers. https://01.org/linuxgraphics/
Hmmmm tired installing and updated bios too, no luck
I really do not want to reconfigure as I have XBOX One remote configuration in place that I no longer rememebr how I got it working with the Baytrail CPU
And here is the log file without any addons (addons folder removed)
http://pastebin.com/x1WNA2An
unplug the xbox remote/controller/receiver and try again. If it doesn't work, enable debug(via advanced settings or kodi --debug)
There is no Reciever the NUC has one inbuilt, its just a custom keymap along with other settings to get it running
log after moving the lirc keymap
http://pastebin.com/gCEj5vh5
(2015-02-15, 08:25)fritsch Wrote: [ -> ]
On a side note, if you want to see the data of the invoking URL in a spreadsheet, you can paste the URL:
into json-csv.com
and all the channel info will be in a spreadsheet.
Here's a permalink snapshot for example:
https://json-csv.com/c/k4Ly
(2015-02-16, 03:30)kindrudekid Wrote: [ -> ]There is no Reciever the NUC has one inbuilt, its just a custom keymap along with other settings to get it running
there are still lots of banned addons in there....
Thanks, I went ahead and restored a clone I made before upgrading to Kodi just incase, did a distupgrade and all is normal....
Only problem is the play/pause button will only play video but not pause it.
And fixed the play pause too
Pages: 1 2
