Full Version: MYSQL and clean library query
Recently moved to a centralised mysql video and music library for my kodi clients and wanted to ask, when files are removed from my NAS, do I need to run the clean database on all kodi clients or just one of them? (my guess is all clients to ensure old texture cache data is removed?)
Thanks in advance for any guidance on this.
As long as you have the advancedsettings set up right on all machines then what changes are made to a library on one will be reflected on the others. As far as the texture cache I am not sure how that works so I don't know if that even gets updated at all when something is removed.
This may help with the clean up if needed http://kodi.wiki/view/Texture_Cache_Maintenance_utility. I have never used it and just found it when do a search for info on the texture cache.
Thanks very much for the advice block134.
