2015-02-21, 13:05
Hello together,
I successfully installed & configured Kodi 14.1 on my Fire TV. Everything is running fine except one thing: if in an MKV container HD Audio is present, then I get only stereo via HDMI to my receiver.
However, the MKV also contains an additional audio format stream, in this case DD 5.1 - a format that is working very well in my environment (also via Kodi & Fire TV). But Kodi does not select it if a HD stream is also available. As a result, I get downsampled stereo, but not DD 5.1
I don't find a way to manually select the alternative audio stream, or [preferred] to tell Kodi that in general it should skip HD audio streams and select alternative ones.
How can I tell Kodi to select the alternative DD 5.1 stream instead of the HD one - either in general or for a specific movie?
Sorry if the question is stupid, but I didn't find anything here in forum or wiki.
Regards,
Kane
Regards,
Kane
