2015-05-20, 10:46
2015-05-20, 12:19
great
ok now builded and installer platform and kodi-platform.
Now i have only a problem on pvr.iptvsimple build:
-- The C compiler identification is GNU 4.8.2
-- The CXX compiler identification is GNU 4.8.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Checking to see if CXX compiler accepts flag -flto
-- Checking to see if CXX compiler accepts flag -flto - yes
-- Found ZLIB: /usr/lib64/libz.so (found version "1.2.8")
-- ZLIB_LIBRARIES: /usr/lib64/libz.so
-- IPTV_VERSION=1.11.2
-- Configuring done
-- Generating done
-- Build files have been written to: /home/armando/tmp/pvr.iptvsimple
[armando@localhost pvr.iptvsimple (master)]$ make
Scanning dependencies of target pvr.iptvsimple
[ 50%] Building CXX object CMakeFiles/pvr.iptvsimple.dir/src/client.cpp.o
/home/armando/tmp/pvr.iptvsimple/src/client.cpp:27:33: fatal error: kodi/libKODI_guilib.h: File o directory non esistente
#include "kodi/libKODI_guilib.h"
compilation terminated.
CMakeFiles/pvr.iptvsimple.dir/build.make:57: set di istruzioni per l'obiettivo "CMakeFiles/pvr.iptvsimple.dir/src/client.cpp.o" non riuscito
make[2]: *** [CMakeFiles/pvr.iptvsimple.dir/src/client.cpp.o] Errore 1
CMakeFiles/Makefile2:94: set di istruzioni per l'obiettivo "CMakeFiles/pvr.iptvsimple.dir/all" non riuscito
make[1]: *** [CMakeFiles/pvr.iptvsimple.dir/all] Errore 2
-- Configuring done
-- Generating done
2015-05-20, 12:23
those files should have been installed by 'make install' of kodi. do you have a <kodi-install-prefix>/include/kodi dir at all ?
2015-05-20, 14:35
ls /usr/include/kodi
DVDDemuxPacket.h xbmc_addon_dll.h xbmc_pvr_types.h
libXBMC_addon.h xbmc_addon_types.h xbmc_scr_dll.h
libXBMC_codec.h xbmc_audioenc_dll.h xbmc_scr_types.h
libXBMC_gui.h xbmc_audioenc_types.h xbmc_stream_utils.hpp
libXBMC_pvr.h xbmc_codec_types.h xbmc_vis_dll.h
util/ xbmc_epg_types.h xbmc_vis_types.h
xbmc_addon_cpp_dll.h xbmc_pvr_dll.h
2015-05-20, 14:51
Right so upstream install target is broken. @wsnipex
2015-05-20, 14:57
i retrying to rebuild with this steps:
$ git clone https://github.com/xbmc/xbmc -b Helix
$ cd xbmc
$ ./bootstrap
$ ./configure --prefix=/usr --libdir=/usr/lib64
$ make
$ sudo make install
$ cd xbmc
$ ./bootstrap
$ make
$ sudo make install
2015-05-20, 15:01
Helix branch won't work. You have to use master
2015-05-20, 15:06
ah missed that bit.
2015-05-20, 15:09
yes i already saw now
1 week ago was added
2015-05-20, 15:59
Finally all is ok
I rewrite all my steps to build Kodi and ITPV Simple Client from git master:
-- KODI --
-- PLATFORM --
-- KODI-PLATFORM --
-- IPTVSIMPLE ADDON --
after that i only needed to add addon from generated zip.
I hope that this steps could help others.
Thanks for support
-- KODI --
$ git clone https://github.com/xbmc/xbmc kodi
$ cd kodi
$ ./bootstrap
$ make
$ sudo make install
-- PLATFORM --
$ git clone https://github.com/Pulse-Eight/platform
$ cd platform
$ cmake . -DCMAKE_INSTALL_PREFIX:PATH=/usr -DCMAKE_INSTALL_LIBDIR=/usr/lib64
$ make && sudo make install
-- KODI-PLATFORM --
$ git clone https://github.com/xbmc/kodi-platform
$ cd kodi-platform
$ git clone https://github.com/kodi-pvr/pvr.iptvsimple
$ cd pvr.iptvsimple
$ cmake . -DCMAKE_INSTALL_PREFIX:PATH=/usr -DCMAKE_INSTALL_LIBDIR=/usr/lib64 -DPACKAGE_ZIP=1
$ make addon-package
Thanks for support
2015-05-22, 17:49
If you just followed the steps shown on post #1 it would have been much easier.
2015-06-15, 02:33
So I wanted to have a go with pvr addons to learn a bit about c++. Unfortunately, I'm having a hard time compiling the pvr addons for hours.
Compiled kodi from git (master) without any issue, platform and kodi-platform also compiled okay. Any pvr addon gives me error when compiling it, something related to some of the header files: libXBMC_addon.h, libKODI_guilib.h.
Here an example with pvr.demo:
http://pastebin.com/G4qrh6QP
Are their versions in kodi-pvr master supposed to compile? Or is it something on my end?
Any help would be appreciated.
Linux arch 4.0.5-1-ARCH #1 SMP PREEMPT x86_64 GNU/Linux
Edit: tried with lower versions of gcc (4.8.4/4.8)... same result
2015-06-15, 18:38
Still couldn't compile any pvr addon. Even using the packages on AUR:
kodi-devel -> https://aur.archlinux.org/packages/kodi-devel/
kodi-devel-platform -> https://aur.archlinux.org/packages/kodi-devel-platform/
kodi-devel-libplatform -> https://aur.archlinux.org/packages/kodi-...bplatform/
kodi-deve-pvr-demo -> https://aur.archlinux.org/packages/kodi-devel-pvr-demo/
Still returns the same error (post above). Any ideas from anyone who actually knows about all this about what might be the reason for it to be failing?
2015-06-15, 18:44
@enen92: you have different headers installed in multiple places:
Quote:/usr/include/kodi/libXBMC_addon.h:94
/usr/local/include/kodi/libXBMC_addon.h:94
2015-06-15, 20:05
All good now Thanks negge
