Full Version: Kodi not showing tv shows on main screen
Ive added my movies to kodi, and I can access all of my movies, but there is no option on the main screen to access my tv shows. (The tv shows aren't live) I can access them through Videos -> Files and they play fine, but there is no option on the main screen.
I'm running openelec 5.0.3 on raspberry pi b+.
Any help would be great
You do realise tv shows have to be added separately?
yep. They are in a separate folder, and I added them as tv shows. I'm using the tv scraper for that folder as well... but there's no tv show option available
You'll need to post a debug log to pastebin of scraping tv shows.
Is it a problem with scraping the tv shows?
And i'm not sure how to get the debug log, is there somewhere where they explain it?
I found it. Ill have it up in a bit
ok... I realize this is off topic, but when I try to upload the log, it says the script failed, unable to upload.
I don't see shows being scraped?
I only see what looks like Movie directories being scraped.
Can you with debugging on, remove a TV source, clean library and then re-add source/scrape a show and re-post the log.
