2015-02-23, 01:46
I haven't used my KodiBuntu system for a few weeks, just went to use it and all my addons are performing really badly. This occurs from the point the addon is started, below is the debug log for simply opening the YouTube addon (which takes nearly 2 minutes):
It wasn't doing this when I last used it. The system is on 24x7 so has probably done a bunch of updates since I last used it. I can't see any problems at the OS level and all other aspects of Kodi (playing local music, videos, etc.) seems to work fine. Can anyone see from the log what the problem could be? Thanks.
Quote:23:33:18 T:139877150550208 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:33:18 T:139877150550208 DEBUG: OnKey: return (0xf00d) pressed, action is Select
23:33:18 T:139877150550208 DEBUG: Clearing cached fileitems [plugin://plugin.video.youtube/]
23:33:18 T:139877150550208 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/)
23:33:18 T:139877150550208 DEBUG: ParentPath = [addons://sources/video/]
23:33:18 T:139876043482880 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','3','')
23:33:18 T:139876043482880 DEBUG: WaitOnScriptResult - waiting on the YouTube (id=21) plugin...
23:33:18 T:139875080644352 NOTICE: Thread LanguageInvoker start, auto delete: false
23:33:18 T:139875080644352 INFO: initializing python engine.
23:33:18 T:139875080644352 DEBUG: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): start processing
23:33:19 T:139877150550208 DEBUG: ------ Window Init (DialogBusy.xml) ------
23:33:42 T:139875080644352 NOTICE: -->Python Interpreter Initialized<--
23:33:42 T:139875080644352 DEBUG: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): the source file to load is "/home/kodi/.kodi/addons/plugin.video.youtube/default.py"
23:33:42 T:139875080644352 DEBUG: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): setting the Python path to /home/kodi/.kodi/addons/plugin.video.youtube:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
23:33:42 T:139875080644352 DEBUG: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): entering source directory /home/kodi/.kodi/addons/plugin.video.youtube
23:33:45 T:139875080644352 DEBUG: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.14.0 of the xbmc.python api
23:34:31 T:139875080644352 NOTICE: [plugin.video.youtube] Starting Kodion framework by bromix...
23:34:35 T:139875080644352 NOTICE: [plugin.video.youtube] Python : 2.7.8
23:34:35 T:139875080644352 NOTICE: [plugin.video.youtube] System : Helix (2.19)
23:34:35 T:139875080644352 NOTICE: [plugin.video.youtube] Context: YouTube (5.0.6)
23:34:47 T:139875080644352 DEBUG: LocalizeStrings: no strings.po file exist at /home/kodi/.kodi/addons/plugin.video.youtube/resources/language/English, fallback to strings.xml
23:34:47 T:139876043482880 DEBUG: WaitOnScriptResult- plugin returned successfully
23:34:47 T:139877150550208 DEBUG: Saving fileitems [plugin://plugin.video.youtube/]
23:34:47 T:139877150550208 DEBUG: -- items: 5, sort method: 0, ascending: false
23:34:47 T:139875072251648 NOTICE: Thread BackgroundLoader start, auto delete: false
23:34:47 T:139875072251648 DEBUG: Thread BackgroundLoader 139875072251648 terminating
23:34:47 T:139875072251648 NOTICE: Thread JobWorker start, auto delete: true
23:34:47 T:139875072251648 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-x86_64-linux.so)
23:34:47 T:139875072251648 DEBUG: Loading: /usr/lib/kodi/system/ImageLib-x86_64-linux.so
23:34:47 T:139876043482880 DEBUG: DoWork - took 141 ms to load special://skin/backgrounds/movies.jpg
23:34:47 T:139877150550208 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
23:34:50 T:139875080644352 NOTICE: [plugin.video.youtube] Shutdown of Kodion
23:34:50 T:139875080644352 INFO: CPythonInvoker(21, /home/kodi/.kodi/addons/plugin.video.youtube/default.py): script successfully run
23:34:52 T:139875080644352 INFO: Python script stopped
23:34:52 T:139875080644352 DEBUG: Thread LanguageInvoker 139875080644352 terminating
