2015-02-23, 03:35
Hi, I'm running OpenELEC 5.0.3 with VDR & vnsi on rPi2 as both backend and client. Watching TV and time shifting works great. It's only when I'm doing anything with recordings (I use the live interface) that things go awry.
I set my Timeshift to a local USB flash drive, and my recording path to a NAS (ext4, NFS) that is mounted on boot with the systemd method here: http://wiki.openelec.tv/index.php/Mounti...ork_shares
Basically, more often than not, when the time comes for VDR to record something, it writes an info, and empty index/TS files, 0 bytes in size. When manipulating timers and recordings, the Live UI tends to crash and sometimes restarts automatically. For example, I tried to cancel a timer; browser gives me the "can't connect" error, I try entering the UI again, it works, and this time around I can cancel the timer successfully. Recordings work sometimes, seemingly randomly. I realise this info is not all that useful without logs, so how would I go about setting the log level in OpenELEC? And where is it stored?
