Full Version: xbmc 13.1 works, kodi 14.1 doesn't
Hello ,
i have a brand new rikomagic MK05. it comes with preinstalled XBMC 13.1 which works fine.
i tried to uninstall it and after reset i tried to install kodi 14.1 ( also tried 14.0 with the same results)
like i wrote XBMC works and kodi does not, it passes the "first run" and then reset itself and gets out to the main android manu. i tries to reset the tv box and still when i try to start it ,it makes the screen black and after a few seconds it goes back to the main manu of the androide
the MK05 has AMLOGIC S805 and quad core mali 450
can you help me fix the problem or at least find it ?
thanks
yaniv
Same thing for me on the new MK12. Have tried to get an answer direct from RKM but no response to date. Will come back if I ever hear from them.
Think im having same issue. Xbmc 13.2 worked, updated to kodi 14.1 and just get a blank screen Sad
Complain to you supplier that they provide proper firmware
(2015-02-28, 18:07)Martijn Wrote: [ -> ]Complain to you supplier that they provide proper firmware
same reply
