2015-02-23, 16:23
Hello,
I think I might have found a minor bug with Aeon Nox 5. I'm using Kodi 14.1 and AN 5.5.6.
As I wanted to keep my Anime separate from the other movies and shows, I've created four smart playlists which I reference everywhere: Movies, Shows, Anime and Anime-Movies. Of course, I've also disabled the default Movies/Shows home menu items and use custom items for the playlists. Here's one of the item actions, for example:
I'm also using movie sets. When I open a set via Videos -> Playlists -> Anime-Movies -> any movie set and then press backspace, I'm back in the Anime-Movies playlist again and the set I just had a look at is selected. Of course, that's how it's supposed to be.
However, when I navigate to a set by using my custom home menu items - for instance, Anime-Movies -> any movie set - and then press backspace, two things are different: First, I'm kicked to the first item of the playlist. Second, the playlist is flattened. Instead of sets, it now displays all movies separately.
When I press backspace another time to return to the home menu and then re-enter the playlist, the sets are back. The list is only flattened after leaving a set, and only if I navigated to the set from a custom home menu item.
I've moved my AN5 settings to try it with vanilla settings - same thing happens.
Could someone please confirm this behavior to make sure it's not just me?
ActivateWindow(VideoLibrary,special://profile/playlists/video/Anime-Movies.xsp,return)
