Full Version: CVS directory removal in Build dir
hello,
i added a line to build.bat to remove all cvs directories copied to the build dir.
Quote:for /r build %%d in (cvs) do @rd /s /q %%d
comes after all copies.
i hope you'll like it.
http://sourceforge.net/tracker....=581840
this doesn't work because there is a cvs folder in every single subfolder and this fix only deals with the cvs's in the root folder. i'm doing a windows search on the build folder for cvs and deleting them that way.
