Hello, I have installed Kodibuntu to run alongside my windows, at the time of installation I was not at home to enter my wifi credentials. Now it will not connect to my network. Is there a way to input this information from this point or do I need to do a fresh install from home.
Thank You
No...
Just 'exit' Kodi (not shutdown) and you will get another desktop with a login window. At the top right corner should be a wrench icon...click on it and select the Lubuntu Session. Then enter the username and the password you give at installation and you will access the Lubuntu desktop environment. At this point you can do some settings for the network under the system settings (or similar). If you have done all your settings you have to 'exit' this session again (not shutdown or reboot). You will see the login window again. Again click on the wrench icon and select the kodi session. Then enter username and password again and you will be logged in in Kodi again and hopefully you have your wifi up and running.
