Full Version: Remove options from OSDAudioSettings popup?
Just wondering if its possible to remove some of the options in the OSDAudioSettings popup that you can get from via the video OSD?
I thought it would be in "VideoOSDSettings.xml" but going through that file it seems to be a very generic place holder that is then populated deeper within kodi... if that's the case it would seem its not editable, but i figured i would ask here before moving on.
Thanks,
Hello, Have you find a solution? I've the same problem.
Paolo
