Full Version: Golf Channel error 403 on NBC Sports Live Extra
Hi, I get everything else to work through NBC sports except the golf channel. I use smartdns to get around geo-location locks.
I have pasted details of the log below and from what i can see there is a 403 error that immediately jumps out, ... Any help appreciated.
19:50:06 T:1969537024 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
19:50:06 T:1969537024 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
19:50:06 T:1969537024 INFO: easy_aquire - Created session to http://tvegolf-i.Akamaihd.net
19:50:07 T:1969537024 DEBUG: CCurlFile::GetMimeType - http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8 -> application/x-mpegURL
19:50:07 T:1969537024 DEBUG: Loading settings for http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers(http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8)
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: streams
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: aacp/sdp
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mp2
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
19:50:07 T:1969537024 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
19:50:07 T:1969537024 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
19:50:07 T:1949299776 DEBUG: CAESinkPiBig Grinrain delay:100ms now:0ms
19:50:07 T:1949299776 DEBUG: CAESinkPiBig Grineinitialize
19:50:07 T:1949299776 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
19:50:07 T:1949299776 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.audio_render handle 0x61d286c0
19:50:07 T:1969537024 NOTICE: DVDPlayer: Opening: http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8
19:50:07 T:1969537024 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
19:50:07 T:1969537024 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
19:50:07 T:1969537024 DEBUG: CMMALRenderer::UnInit
19:50:07 T:1969537024 DEBUG: CMMALRenderer:TonguereInit
19:50:07 T:1676670016 NOTICE: Thread DVDPlayer start, auto delete: false
19:50:07 T:1676670016 NOTICE: Creating InputStream
19:50:07 T:1676670016 DEBUG: CFileCache::Open - opening <hls/live/218225/golfx/4296k/prog.m3u8> using cache
19:50:07 T:1676670016 DEBUG: CurlFile::Open(0x626c2fc0) http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8
19:50:08 T:1676670016 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
19:50:08 T:1676670016 NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
19:50:08 T:1676670016 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
19:50:08 T:1676670016 ERROR: Open - failed to open source <http://tvegolf-i.Akamaihd.net/hls/live/218225/golfx/4296k/prog.m3u8>
19:50:08 T:1676670016 NOTICE: Creating Demuxer
19:50:08 T:1676670016 DEBUG: ffmpeg[63EFF440]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
19:50:08 T:1969537024 DEBUG: Previous line repeats 1 times.
19:50:08 T:1969537024 DEBUG: ------ Window Init (DialogBusy.xml) ------
19:50:08 T:1676670016 DEBUG: ffmpeg[63EFF440]: [http] HTTP error 403 Forbidden
19:50:08 T:1676670016 DEBUG: Error, could not open file http://tvegolf-i.Akamaihd.net/hls/live/2.../prog.m3u8
