Full Version: Problems compiling new CVS builds
i performed a checkout this afternoon and i keep getting the following errors when i try to compile todays build:
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(81): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(376): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(381): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(382): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(399): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(400): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(427): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(429): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(431): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(432): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2266): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2292): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2733): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2775): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2821): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(2887): warning c4244: '=' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3184): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3210): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3243): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3472): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3502): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
e:\xbmc\xbmc\xbmc\cores\sscc.cpp(3537): warning c4244: 'initializing' : conversion from 'double' to 'real', possible loss of data
xbmc warning im1029: library xonline is unapproved
xbmc warning im1030: this image may not be accepted for certification
xbmc error x1001: could not connect to xbox ''
while i'm used to seeing the last 3 lines, the sscc.cpp module has crapped out 3 times. i've checked out new binaries twice, so it appears consistient.
any thoughts?
those compiler warnings are nothing to worry about. i'll fix them tonight (was too lazy to do it when i submitted them!Wink
it's just because the ssrc library can use either floats or doubles in it's calculations. we have it set to use floats (ie real is defined as float), so when it sees what would normally be a double computation (eg 0.5*something) it warns about losing precision.
ah, okay.
i've not seen so many warning when compiling.
thanks for the tip...
moving to "support (help)". we try to keep the dev forum clean since many ppl are compiling their own builds. Smile
