how can i change the default value 20 in recently added widget from Home menu? (when I press UP on for example MOVIES and choose Recent)
It does not use the built in <recentlyaddeditems> found in advancedsettings.xml as far as i can tell, but i'd like it to either do that or find where i can change 20 to 100.
Cheers in advance
Wimpy
You can add new entries for recent movies editing the "Includes_Shelf_Contents.xml" file - line 287.
Add new "items" to the "RecentMovieContent" include changing the id and numbers accordingly.
Tgx
Hi and thanks for the reply.
<item id="20">
<visible>!IsEmpty(Window(Home).Property(RecentMovie.20.Title))</visible>
<label>$INFO[Window(Home).Property(RecentMovie.20.Title)]</label>
<thumb>$INFO[Window(Home).Property(RecentMovie.20.Art(poster))]</thumb>
<property name="ItemType">$LOCALIZE[31961]</property>
<property name="Plot">$INFO[Window(home).Property(RecentMovie.20.Plot)]</property>
<property name="Rating">$INFO[Window(home).Property(RecentMovie.20.Rating)]</property>
<property name="Year">$INFO[Window(home).Property(RecentMovie.20.Year)]</property>
<property name="Runtime">$INFO[Window(home).Property(RecentMovie.20.Runtime)]</property>
<property name="Genre">$INFO[Window(home).Property(RecentMovie.20.Genre)]</property>
<property name="Mpaa">$INFO[Window(home).Property(RecentMovie.20.MPAA)]</property>
<property name="VideoCodec">$INFO[Window(home).Property(RecentMovie.20.VideoCodec)]</property>
<property name="VideoResolution">$INFO[Window(home).Property(RecentMovie.20.VideoResolution)]</property>
<property name="AudioCodec">$INFO[Window(home).Property(RecentMovie.20.AudioCodec)]</property>
<property name="AudioChannels">$INFO[Window(home).Property(RecentMovie.20.AudioChannels)]</property>
<onclick>PlayMedia($ESCINFO[Window(Home).Property(RecentMovie.20.File)])</onclick>
</item>
<item id="21">
<visible>!IsEmpty(Window(Home).Property(RecentMovie.21.Title))</visible>
<label>$INFO[Window(Home).Property(RecentMovie.21.Title)]</label>
<thumb>$INFO[Window(Home).Property(RecentMovie.21.Art(poster))]</thumb>
<property name="Plot">$INFO[Window(home).Property(RecentMovie.21.Plot)]</property>
<property name="Rating">$INFO[Window(home).Property(RecentMovie.21.Rating)]</property>
<property name="Year">$INFO[Window(home).Property(RecentMovie.21.Year)]</property>
<property name="Runtime">$INFO[Window(home).Property(RecentMovie.21.Runtime)]</property>
<property name="Genre">$INFO[Window(home).Property(RecentMovie.21.Genre)]</property>
<property name="Mpaa">$INFO[Window(home).Property(RecentMovie.21.MPAA)]</property>
<property name="VideoCodec">$INFO[Window(home).Property(RecentMovie.21.VideoCodec)]</property>
<property name="VideoResolution">$INFO[Window(home).Property(RecentMovie.21.VideoResolution)]</property>
<property name="AudioCodec">$INFO[Window(home).Property(RecentMovie.21.AudioCodec)]</property>
<property name="AudioChannels">$INFO[Window(home).Property(RecentMovie.21.AudioChannels)]</property>
<onclick>PlayMedia($ESCINFO[Window(Home).Property(RecentMovie.21.File)])</onclick>
</item>
this shows a new item, but same as #20.. what am i doing wrong?
Edit: now reverted file back the way it was and still shows #21 entries under Movies for some reason.
I'm not an expert, but it seems the skin widgets addon has an hardcoded limit of 20 items.
So adding items over 20 will not work.
Tgx
