i cant figure that out,
i made a playlist of shows with watched episodes 0
i cant make an episode playlist with shows from the previous playlist.
any help would be helpful.
thanks
I think there is a way to do this, but I don't think it directly works with two playlists. That is, a show-level playlist and an episode-level playlist, as Kodi doesn't understand how to make the two levels relate to each other, or something like that (maybe..).
It might require a little bit of logic that smart playlists don't normally do. I think the Lazy TV add-on can do something close to this.
(2015-03-01, 22:23)Ned Scott Wrote: [ -> ]I think there is a way to do this, but I don't think it directly works with two playlists. That is, a show-level playlist and an episode-level playlist, as Kodi doesn't understand how to make the two levels relate to each other, or something like that (maybe..).
i'm using lazytv, the playlist it does is new epidsode on already watched shows, you cannot change the smart playlist it makes...
