(2015-04-08, 00:28)mladen.perisic Wrote: [ -> ]Hello guys! I have similar problem for quite some time. I'm using OpenELEC for several years. I tried on OE IRC channel but guys there told me it's a problem with kodi FileManager, not OE and to try to find help here. I tried kodibuntu 14 also and the problem is the same right after clean install.
I have OE 5.0.8 (kodi 14.2) installed on SSD and one additional HDD with data (one partition, EXT4 FS, owner)
On OE version 4.x (XBMC 13.x) everything works fine.
The problem occurs when trying to move files using kodi File Manager from one fs to another (from profile folder on SSD to Data partition on HDD).
Here are the logs: https://www.dropbox.com/s/j2js9enc1hbx26...7.zip?dl=0 and here is relevant excerpt from log on PasteBin: http://pastebin.com/JhX5YcrG
I hope this problem will be fixed soon. I'm stuck on old version of OE because of this problem.
Thank you!
Fix already merged in master with
https://github.com/xbmc/xbmc/pull/6582 so you no longer have an excuse to be "stuck" with old version.
Big thanks to you uNiversal and to all the guys from bug fix team on github for providing quick answers and fixing the problem!
Do you think the bug fix will be included in some version of helix or it will be included only in 15 versions?
Guys from OE thinks that bug fix gone into next kodi version, which means I will need to wait for OE 6. Is that true?
http://openelec.tv/forum/72-xbmc/76391-w...0-9#137380
seems we forgot to backport this fix to Helix 14.2 :/
(2015-04-08, 08:26)mladen.perisic Wrote: [ -> ]Big thanks to you uNiversal and to all the guys from bug fix team on github for providing quick answers and fixing the problem!
Or try a OE build with kodi v15 alpha2 or in three of weeks wiill be v15 beta1
Everything is clear now, will wait for new version.
Guys, thank you a lot!
(2015-04-08, 10:06)uNiversal Wrote: [ -> ] (2015-04-08, 08:26)mladen.perisic Wrote: [ -> ]Big thanks to you uNiversal and to all the guys from bug fix team on github for providing quick answers and fixing the problem!
Guys, I just upgraded to OE 6 beta 2 and the problem still exists. Is the bf merged? Should I fire up clean install and test again?
(2015-07-12, 20:46)mladen.perisic Wrote: [ -> ] (2015-04-08, 10:06)uNiversal Wrote: [ -> ] (2015-04-08, 08:26)mladen.perisic Wrote: [ -> ]Big thanks to you uNiversal and to all the guys from bug fix team on github for providing quick answers and fixing the problem!
Hello again! After trying OE 6 beta 4 (both clean install and upgrade) I can confirm that this bug is finally eliminated and moving files across different fs from kodi file manager is working as it should.
Tnx again to all developers for giving us this great piece of SW!
