2015-02-27, 15:36
When I update library, the process hangs. Then, when I try to exit Kodi, it freezes - doesn't exit, just sits there unresponsive to any other commands.
My setup consists of:
- MySQL database backend
- NFS shares for movies and TV shows (defined in sources.xml with a couple of additional paths manually added through Kodi)
- Path substitutions for thumbnails (defined in advancedsettings.xml)
The client on which the issue first occurred was a Fire TV with SPMC (based on Kodi 14.1) running the Eminence skin.
All was working fine until I added the path substitutions for the thumbnails.
I deleted the local thumbnails db file and the SQL databases. The library update would process 4 or 5 films and then hang. When I force quit Kodi and go back in, those 4 or 5 films that were successfully added to the library have all the correct info, thumbnails etc.
I have then since tried the following:
- Deleted the sources and re-added them
- Reinstall SPMC
- Setup Kodi on my laptop with the same sources.xml and advancedsettings.xml
But the same thing happens.
I've put the debug log below.
Can anyone please help? Many thanks in advance!
- Reinstall SPMC
PHP Code:
23:04:28 T:8816 DEBUG: VideoInfoScanner: Adding new item to movies:nfs://10.20.36.4/volume2/video/movies (1080p)/Godzilla/Godzilla.2014.1080p.BluRay.x264-SPARKS.mkv
23:04:36 T:5276 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
23:04:37 T:5276 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.xbmc.org (easy=0AF74808, multi=006A88F0)
23:04:41 T:5276 DEBUG: ------ Window Init (Pointer.xml) ------
23:04:47 T:5276 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:04:57 T:4600 DEBUG: Thread JobWorker 4600 terminating (autodelete)
23:04:57 T:5276 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://image.tmdb.org (easy=00661AE8, multi=0AF607C8)
23:04:58 T:5276 INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://api.tmdb.org (easy=0AFE0170, multi=0AF60740)
23:05:15 T:4020 DEBUG: CAESinkDirectSound::Deinitialize: Cleaning up
23:07:43 T:5276 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
23:07:43 T:5276 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
23:07:43 T:5276 DEBUG: ------ Window Init () ------
23:07:43 T:1256 DEBUG: service.libraryautoupdate-0.9.4 : screen saver on
23:09:11 T:5220 DEBUG: Thread RemoteControl 5220 terminating
23:10:25 T:5276 DEBUG: CWinEventsWin32::WndProcWindow is active
23:10:27 T:5276 DEBUG: CJoystick::Initialize : No Joystick found
23:10:27 T:5276 DEBUG: CWinEventsWin32::WndProcWindow is active
23:10:27 T:5276 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
23:10:27 T:5276 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
23:10:27 T:5276 DEBUG: ------ Window Init (Pointer.xml) ------
23:10:27 T:1256 DEBUG: service.libraryautoupdate-0.9.4 : screen saver off
23:10:28 T:5276 DEBUG: ------ Window Deinit () ------
23:10:33 T:5276 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:10:37 T:5276 DEBUG: ------ Window Init (Pointer.xml) ------
23:10:44 T:5276 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:13:40 T:5276 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
23:13:40 T:5276 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
23:13:40 T:5276 DEBUG: ------ Window Init () ------
23:13:40 T:1256 DEBUG: service.libraryautoupdate-0.9.4 : screen saver on
23:15:40 T:5276 DEBUG: CWinEventsWin32::WndProcWindow is active
23:31:18 T:5276 DEBUG: CJoystick::Initialize : No Joystick found
23:31:18 T:5276 DEBUG: CWinEventsWin32::WndProcWindow is active
23:31:19 T:5276 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
23:31:19 T:5276 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
23:31:19 T:5276 DEBUG: ------ Window Init (Pointer.xml) ------
23:31:19 T:1256 DEBUG: service.libraryautoupdate-0.9.4 : screen saver off
23:31:20 T:5276 DEBUG: ------ Window Deinit () ------
23:31:22 T:5276 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
23:31:22 T:5276 DEBUG: Activating window ID: 10111
23:31:22 T:5276 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
23:31:22 T:5276 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
23:31:24 T:5276 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
23:31:24 T:5276 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
23:31:24 T:5276 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
23:31:24 T:5276 NOTICE: Storing total System Uptime
23:31:24 T:5276 NOTICE: Saving settings
23:31:24 T:5276 NOTICE: stop all
