Hi GUYS,
MASSIVE PROBLEM HERE MY WEE BOY SEEMS TO HAVE RESTORED MY XBMC BOX AND NOW EVERYTHING IS GONE ?
IS THERE ANYONE WHO CAN HELP PLEASE
MANY THANKS BRIAN
MX ANDROID 4.2.2 DUAL CORE SMART XBMC
The Gbox MX?
Is it booting into the OS or is it booting into XBMC and your shows are gone?
ITS GOT
JELLY BEAN
DUAL CORTEX-A9
DUAL MALI-400
ITS BOOTS UP AS NORMAL .. BUT WHEN I WENT TO APP SCREEN MY KODI ICON WAS MISSING
try turning OFF capslock, maybe that fixes at least typing
cheers but not really the help I was looking for
(2015-02-27, 19:37)shaggybaws Wrote: [ -> ]cheers but not really the help I was looking for
Yeah... you need professional grammar help, more than what you can get here.
On topic though: if someone factory reset your box, and your previous installation and library only existed on that box, there is nothing you can do short of re-installing Kodi and addons, and then re-creating your library.
If you had your library and/or SQL database elsewhere (on PC somewhere) then you just need to re-install Kodi and connect to your library/DB again.
