I have a MCE remote with a USB IR receiver. This works well in combination with RPi. Having said this, the receiver itself is larger than the RPi, which deserves a bit of the purpose... Wanted to check whether it is possible to add a small IR receiver to the RPi (without USB), which works with my MCE remote? Any difference in answer for RPi-B, RPi-B+ or RPi2? Thanks!!!
There really needs to be an up to date guide, most guides include a lot of now unecessary steps.
Google for GPIO remote. In short, you need a 38KHz IR receiver that can operate at 3.3V. I'm using a TSOP34838. You need to wire it to the GPIO pins as shown in these guides, i.e. 3.3V, GND, and use pin 18 so there's little else to configure.
If you're using OpenELEC (you didn't say), all you still need to do now is add one more entry to config.txt, i.e.:
device_tree_overlay=lirc-rpi
Reboot, and you should now find your MCE remote working.
Thanks, very much appreciated. I am indeed using openelec.
Above appears quite straight forward. When you say "wire", does this actually require me to do soldering? I am not too handy with these things and also wouldn't have the tools. Is there any way to avoid the soldering?
No it doesn't require any soldering. you can connect it via wires, but you can get mce receivers that are small. rosewill sells one. you can also get flirc which is really small.
There's also this prebuilt one that lays right over the GPIO pins:
www.honeypi.com They also provide a key map for MCE remotes w/ it, that works quite well right out of the box. It does draw a bit of power from the Pi but still works excellently if you aren't button mashing the remote.
Got that toshiba one myself but suffer from missed keypresses that didnt happen with a usb receiver. Got an RF mce remote with a usb small dongle and its working perfectly (Emprex 3009ARF).
Cheap BT USB dongle + cheap Bluetooth PS3 remote works very well with Openelec.
Remap a few buttons with the Keymap Editor Add-On and your good to go.
http://kodi.wiki/view/Add-on:Keymap_Editor
Don't even have to point the thing at the RPi
Thanks for all your replies. This is very helpful. I'd still have a small preference for an "internal" solution over a USB dongle. Few questions on the Toshiba one that two of you have been using:
1) What do you mean by "missed keypresses"? Is that about that you need to point to the IR receiver very directly and the range not being too great?
2) Do you have cases and does the Toshiba one fits into a normal cheap case?
3) The first reply referred to 38khz/3.3v. Is that what the toshiba set does?
4) I do not plan to use the "ugly" Toshiba remote, but would just buy it for the IR thingie and then use a different MCE remote. Will any MCE remote works with this thing and openelec out of the box?
5) Where is the remote eye? It'sweird that I cannnot really spot it from the photos
Thanks again!!!
4, yes it works with my other mce remotes
5, the remote eye , when sitting on pins on the the long side of rpi. It will point away from the rpi
I have not seen any missed keypresses so far on my rig
Could be just bad luck in my case but after seen other posts elsewhere of people having issues with the gpio ir receiver. It doesnt handle keypresses well in my case when kodi is busy, i.e. loading epg, playing a 1080p mkv etc
http://forum.kodi.tv/showthread.php?tid=220163
The toshiba remote itself is very nice to use.
