I am having Kodi crashes almost directly after wake-up, however they seem to occur after longer sleep periods. These crashes are also present in 14.1 But i am now testing / using 14.2 beta and they still occur. Since its not a regression i posted in the regular OS X thread. the crash log is posted
http://pastebin.com/Pu5DBFU6
KODI 14.1 BETA 1 GIT 2015-02-17
OSX 10.10 on a Mac Mini 2011 8GB RAM with intel 3000 HDMI to a receiver
Perhaps you can take a look at it.
in which state did it enter sleep? Also could you provide the
debug log (wiki) aswell (ideally both - crash report and
debug log (wiki) from the same crash event)
i enable sleep by putting the entire mac mini in sleep mode.
I think i am on to something with the shares from OS X not being ready yet and KODI creating a lot of errors around that and crashing. Just to be sure ill just wait for the next crash for both logs. to be continued.
i ment in which state kodi is when you put the mac to sleep (f.e. is it playing a movie or paused playback or in which window it sits at that moment)
Memphiz,
I always return to the kodi home screen before putting the system to sleep.
just to let you know. I tested with the option " update library on start-up" switched off and kodi did not crash. So ill switch it on again and check tomorrow if my suspicions are right.
I also experience this (assumed it was something dodgy on my individual system as have been 'fiddling' of late). My guess is this started from v14.1 onwards - this Mac is a new introduction into my setup and started off life with v14 and it didn't crash on wakeup at first.
Mine is generally left sitting on the home screen or tv/movie listing - i.e. no media playing nor paused. Also I have NOT got update library on start-up would would suggest it is unlikely to be this.
Tried two things:
1) Waking up via screen sharing (to rule out my remote control setup being the culprit) = same crashing result
2) Enabled debug logging Saturday mid-morning, let it sleep, woke it up Saturday mid-afternoon (actually wanted to watch something!) = NO crash.. seems it has to sleep for a certain period of time to then happen.
What I can say is with the use pattern of watching it one evening, it then sleeping and coming to watch it the following evening (eg. approx. 20 hours later) = wakes in a crashed state now 100% of the time.
I could perhaps try going back to v14 over the weekend to see if I can confirm the regression between that and v14.1 if that helps?
Simon
The situation today is as Simonw500 described NO crash this morning with the library update turned on. So the library update is probably not the cause.
I can confirm that the crashes, in my experience / what i remember
, occur indeed after longer sleep periods and that they occur since kodi 14.
I'll test the longer than 20 hours later theory and report back. strange bug to chase.
simonw500 please post the crashreporter file - want to be sure that yours is the same crash in libnfs
thats different then the first one and the log has no debugging enabled ( see
debug log (wiki) )
(2015-03-06, 11:07)Memphiz Wrote: [ -> ]simonw500 please post the crashreporter file - want to be sure that yours is the same crash in libnfs
Debug logging enabled first thing this morning.. will hopefully acquire logs when I come to use it this evening.
(2015-03-07, 13:08)Memphiz Wrote: [ -> ]thats different then the first one and the log has no debugging enabled ( see debug log (wiki) )
i'll enable debugging this evening. With some luck i'll have a log tomorrow morning
Hi - did this one ever get resolved? Thanks.
With the Pulse Eight CEC adapter connected, Kodi will always crash on wakeup. The crash is immediate once the system wakes. Anyone manage to sort their issues with this adapter out?
