(2016-01-12, 17:23)maverick72 Wrote: [ -> ]Bought a Shield today.... Kodi and Netflix on my nas was "ok" but wanted a better experience. It was this or Wetek core and since the core is out of stock and i was able to grab a shield with a lower price then i did not hesitate. The fact that Nvidia is still improving the box is also a great factor.
Any goto guide to setting up/tune the perfect shield?
you need a guide if its a custom hack or something. No such thing necessary with the shield. Just install Kodi and get your addons and you are done,.
Anyone had an issue where taking a screenshot results in an all black png? I swear this thing was working fine before...
any best settings for shield around the advanced settings / xml mods?
(2016-01-13, 03:29)ECEC Wrote: [ -> ]Anyone had an issue where taking a screenshot results in an all black png? I swear this thing was working fine before...
If it is playing back video media, yes I get a black screen, I figured this was normal. I have taken screen shots with the Shields option and it shows everything, same with recording, except you need to turn pass-through audio off to capture it of course.
Kodi screenshot:
Shield Screenshot:
Mine go to Google Drive folder on my NAS, I like the IFTT trigger idea, wonder if I can get that working with imgur, although twitter would be fine and immediately reduce the size.
Looking at that twitter account, you seem to take a lot of screenshots.
(2016-01-13, 05:46)Hiphopopotamus Wrote: [ -> ]Mine go to Google Drive folder on my NAS, I like the IFTT trigger idea, wonder if I can get that working with imgur, although twitter would be fine and immediately reduce the size.
Not really, I just forgot I had 60 something screenshots in the folder when I setup the dropbox/IFTTT thing, so they all posted at once. Luckily only me and two other people were following the twitter account, but I felt vaguely bad about spamming their feed with bad screens of a bunch of random stuff.
At some point I really want to make/request a mod for Eminence that doesn't has a minimal OSD on pause, or fades the OSD in over time, or something.
Can anyone advise me on how I can transfer files to the NVIDIA Shield remotely?
Normally I've always used ES FIle Explorer on my Android devices but the SHIELD, for some reason, has never worked. The only time it ever seems to work with ES File Explorer is when the SHIELD is connected via wifi but that no longer seems to work either. :/
Is there a firewall or something on the device that is preventing a connection being established with the SHIELD for file transfer? I tried an alternative, stand-alone FTP app but that didn't seem to work either when I tried it a few weeks back so I'm led to think that it is the device that is the problem. This has been bugging me for some time as I can't quickly modify Kodi skin files for testing purposes.
Would really appreciate any help or advice and would be great to hear if others are experiencing similar issues.
(2016-01-13, 17:06)Hustler1337 Wrote: [ -> ]Hi,
I am going to guess it may have something to do with root access being disabled. You may have to turn on the developers options, although I am not sure if that gives you root access either.
For the record, I have never been able to remote into an android device, fire tv or shield. Then again I have not tried real hard to do it either.
Have you tried using the es file explorer android TV option?
I think he is asking about transferring files to Shield remotely (FTP/SSH/SMB, etc)
Is anyone able to review my Mediainfo below from the movie that I had stuttering/lag occuring? Thanks
General
Complete name : Movie.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/avc1)
File size : 3.96 GiB
Duration : 3h 20mn
Overall bit rate mode : Variable
Overall bit rate : 2 824 Kbps
Encoded date : UTC 2011-08-11 17:23:51
Tagged date : UTC 2011-08-11 17:23:51
Xtra : WM/MediaClassPrimaryID
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3h 20mn
Bit rate : 2 422 Kbps
Maximum bit rate : 12.5 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.066
Stream size : 3.39 GiB (86%)
Writing library : FASM Quality Enhancer Bitrate Squeezer 5.0 ©2011 Fachman
Tagged date : UTC 2011-08-11 17:26:44
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3h 20mn
Bit rate mode : Variable
Bit rate : 399 Kbps
Maximum bit rate : 460 Kbps
Channel(s) : 2 channels
Channel(s)_Original : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 572 MiB (14%)
Language : English
Encoded date : UTC 2011-08-11 17:26:21
I personally no longer use ES, I find X-Plore to be far better
https://play.google.com/store/apps/detai...lore&hl=en
For FTP, follow this guide, works very well -
http://nvidiashieldzone.com/index.php/tu...ndroid-tv/
Now the only time I use an internal file manager such as X-Plore is to sidelaod APKs, everything else gets done via FTP as it’s so easy.
