2017-01-08, 12:09
(2017-01-07, 11:21)wrxtasy Wrote: [ -> ](2017-01-07, 09:44)KaBoS Wrote: [ -> ]I am confused I do not know buy NVIDIA SHIELD 2 or Minix NEO Z83-4The simple Answer is do you need to use Android Apps. Particularly for viewing Protected online, streamed video content very easily from Apps like Netflix, Amazon etc ?
Do you want a device that is basically Plug N Play and only having to use one App for Kodi use only - that being the Kodi for Android TV optimised App - SPMC ?
(no need for MX Player at all)
Would you like to Voice Search your entire Kodi media Library. ?
Need ChromeCasting capabilities ?
Wireless remote controllers ?
Android TV, hands down is much easier to use as a integrated, versatile, flexible media player device compared to Windows.
Personally I would go with the device that is the easiest to use day to day, with fewer bugs and better ongoing support.
Otherwise for Android devices you turn into a media player Firmware test pilot.
This is very important for any Android media player.
If I wanted Video Post Processing of the decoded video I would fiddle with my TV's video Enhancement settings instead of buying any inferior Android Kodi media player.
Next question...
What type of media do you consume ?
List codecs, resolutions, audio etc, particularly important for upscaling ?
I'm not that clued in with MPC-HC & madVR on Windows, but I believe you will very likely get better quality video upscaling of non 1080p content using that combo than with the Shield. Someone with more knowledge about video upscaling on both devices will be able to give you a better answer.
Are you aware of the MPC-HC External Player drawbacks as listed HERE ?
Thank you so much wrxtasy To reply
IA little bit streamed video
_________
__________
Plug N Play and only having to use one App for Kodi use only = Yes of course
(no need for MX Player at all) = i need MX Player Because I can Full control subtitles Height line,shadows ,etc.
These options do not exist in the Kodi default player .
___________
Some times
_____________
Of course I agree with you
_____________
Next question...
________________
For me This is a very important point
I wanted a device Windows to only for MPC-HC & madVR
I did not personally try madVR But I find a lot talking about madVR
madVR The best picture quality madVR Best of Show Filter , etc
I watched this a month ago MPC-HC External Player but the first & last page Only
My Movies , h.264 MKV Blu-ray 1080p Multi some Encoder & REMUX / Audio 5.1 Dts or DD , True or dts-mas
My Music VID & Others Videos , MP4 & AVI
Some videos / 4K h.264 or h.265
Yesterday
Before watching your reply
I read many review to nvidia shield & minix
And Yesterday I pre order nvidia shield
Oh man Wonderful device
No comparison With MINIX
And After reading your reply
I knew that I chose the right option
Thank you so so much .
