Full Version: [RELEASE] Rapier 8.8.15 for Kodi 15 Isengard [DEPRECATED]
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
UPDATE: Rapier 8.8.12 is available through the official Kodi repository!
This update is installed automatically.
If this is not the case, you can download it here.
As we are getting close to Kodi 17 Krypton RC's, this marks one of the last updates for Kodi 15 Isengard.
If you haven't done so already, I highly recommend updating to Kodi 16 Jarvis or Kodi 17 Krypton betas, as the new features are incredible! Smile
The highlights are:
  • The login screen has been updated and adjusted.
  • Skin Settings > Supported Add-ons has been changed into two sections:
    Automatic installation from Kodi add-on repository: will feature all supported add-ons from the official repository. Clicking the add-ons will either prompt you to install them or open up the settings dialog.
    Manual installation: will feature all supported add-ons not in the official repository. Manual installation from zip is required.
  • Paused and Buffering labels has been added to the fullscreen music window with a skin setting to enable/disable. Screenshot below.
  • Noto Sans font has been added, which is a very nice looking, modern font.
FULL CHANGELOG
8.8.12 (18-October-16)
- Added Noto Sans font.
- Update of slideshow window.
- Added new fallback image in Favourites dialog.
- Update of Skin Settings > Supported add-ons section with "Manual installation" section.
- Updated login screen.
- PVR radio improvements and updates.
- Home screen weather category will take you to weather settings if no weather add-on is installed.
- Added support for LibreELEC settings (home screen System category submenu).
- Fullscreen video window Paused label will now also show buffering.
- Added Paused / Buffering labels to fullscreen music window.
ENJOY!
Important info!
It looks like translations at Transifex have stalled. Because of that, I have created my own Transifex project - at least until the official one is up and running.
Please join it to translate this skin once again.
--link removed--
I need all the help I can get Wink
Cheers
Gade
Transifex is up and running again, so it's once again back to translating at this location:
https://www.transifex.com/teamxbmc/kodi-...in-rapier/
Merry christmas everybody!
UPDATE: Rapier 8.8.14 is available through the official Kodi repository!
As we are getting close to the release of Kodi 17 Krypton, Rapier for Kodi 15 Isengard will soon be deprecated.
The highlights are:
  • Improved PVR recording window with added media flags. Screenshot below.
  • Play button has been added in the album information window.
  • Clicking Back on all widgets will go to the first item in the list.
  • When playing music, home screen progress bar is changed to blue. Screenshot below.
FULL CHANGELOG
8.8.14 (19-December-16)
- Added additional home screen custom category images.
- Clicking Back on all widgets will go to the first item in the list.
- When playing music, home screen progress bar is changed to blue.
- Updated skin settings for artwork downloader to match supported artwork types.
- Added close button to text viewer dialog.
- Updated language strings from Transifex.
- Fixed VC-1 codec media flags.
- If no trailer is available, trailer buttons will display "Search Trailer".
- Added media flags for PVR recordings.
- Improvements of artist / album information window.
- Added Play button in album information window.
ENJOY!
UPDATE: Rapier 8.8.15 is available through the official Kodi repository!
Now that Kodi 17 Krypton final version is released, Rapier for Kodi 15 Isengard is deprecated!
If you haven't done so already, I highly recommend updating to Kodi 16 Jarvis, Kodi 17 Krypton or Kodi 18 Leia nightlies, as the new features are incredible! Smile
The highlights are:
  • A Reload Skin button has been added to Skin Settings > Skin Settings.
  • A subtitle delay label has been added for the subtitle delay button in the fullscreen video OSD.
FULL CHANGELOG
8.8.15 (24-January-17)
- New status bar battery notification.
- Added "Add-on Settings" button to top options menu bar when an add-on is running.
- List View normal style now defaults to file icon when no icon is available.
- Fix for home screen widget fanart.
- Added subtitle delay label for subtitle delay button in the fullscreen video OSD.
- Added Reload Skin button to Skin Settings > Skin Settings.
ENJOY!
