2015-05-19, 19:59
2015-05-31, 12:41
Anyone else have problems to login? I've tried changing my password to something without special characters, removed the plugin, addon-data and cache and re-installed but I still can't login. I checked the error-log and found this:
12:39:24 T:140479143602240 ERROR: GetDirectory - Error getting plugin://plugin.video.vimeo/sign/in/
12:39:24 T:140479143602240 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vimeo/sign/in/) failed
12:39:24 T:140479143602240 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.vimeo/)
12:39:24 T:140479143602240 DEBUG: Loading items: 3, directory: plugin://plugin.video.vimeo/ sort method: 0, ascending: false
2015-05-31, 13:11
(2015-05-31, 12:41)dencrypt Wrote: [ -> ]Anyone else have problems to login? I've tried changing my password to something without special characters, removed the plugin, addon-data and cache and re-installed but I still can't login. I checked the error-log and found this:Can you provide a full debug log (wiki) via pastebin.com or similar service.
2015-05-31, 16:32
2015-05-31, 16:35
(2015-05-31, 16:32)dencrypt Wrote: [ -> ]http://pastebin.com/zxHjFw72
I wrote FULL debug log (wiki) not only a part of it . I need to see the system and maybe errors happening before. I tested the addon just know with a password only existing of special characters and at the maximum length - login is working fine for me.
Was the addon working before? Is your login working on the webpage. Please some more information, so I can help
2015-05-31, 18:43
Sorry.
However now it works. Don't know how though. I did put on debug again. Reset the log-file and restarted Kodi. And suddenly I could login again. Thanks anyway and sorry for taking up your time man. I have no idea why it didn't work after other restarts...
2015-05-31, 18:47
(2015-05-31, 18:43)dencrypt Wrote: [ -> ]Sorry.
No problem I'm glad it's working for you thanks for the feedback
2015-06-08, 17:25
Hello Bromix, I am testing Rob's support for YouTube add-on in VideoExtras, so far so good and with room for improvement (mainly handling a way to better exiting youtube back into VideoExtras and the dowload option, the later I believe is being taken care of in your to do list.
Hope you don't mind a question for you: would you be able to expose similar end points ("Search" interface) for this Vimeo add-on in Github? If so, then support for Vimeo may be viable in VideoExtras too.
http://forum.kodi.tv/showthread.php?tid=...pid2023955
2015-06-08, 18:57
(2015-06-08, 17:25)capfuturo Wrote: [ -> ]Hello Bromix, I am testing Rob's support for YouTube add-on in VideoExtras, so far so good and with room for improvement (mainly handling a way to better exiting youtube back into VideoExtras and the dowload option, the later I believe is being taken care of in your to do list.
Done
Version 4.1.3 (2015-06-08)
ADD: Endpoints search
UPD: code cleaning
2015-06-08, 22:02
(2015-06-08, 18:57)bromix Wrote: [ -> ](2015-06-08, 17:25)capfuturo Wrote: [ -> ]Hello Bromix, I am testing Rob's support for YouTube add-on in VideoExtras, so far so good and with room for improvement (mainly handling a way to better exiting youtube back into VideoExtras and the dowload option, the later I believe is being taken care of in your to do list.
Done
UPD: code cleaning
Hi bromix,
Thanks for doing that - just playing about with calling the interface - I did notice that if you send it non ascii characters then it generates a script error.
It's not a big deal, as I can always strip out those characters before passing it, but noticed that your YouTube addon handles them OK to thought I'd post it in case you were not aware of this.
20:55:10 T:2968 NOTICE: [plugin.video.vimeo] Running: Vimeo (4.1.2) on Helix (14.0) with Python 2.7.8
20:55:10 T:2968 DEBUG: [plugin.video.vimeo] Path: "/search/
20:55:10 T:2968 DEBUG: [plugin.video.vimeo] Params: "{'q': u'The Breakfast Club \xe9 Extras'}"
20:55:10 T:2968 DEBUG: [plugin.video.vimeo] Setting content-type: "episodes" for "/search/"
20:55:10 T:2968 ERROR: C:\XBMC\Kodi-14-Helix\system\python\Lib\urllib.py:1288: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
return ''.join(map(quoter, s))
20:55:10 T:2968 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: u'\xe9'
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\client.py", line 442, in _percent_encode
result = urllib.quote_plus(s).replace('+', '%20').replace('*', '%2A').replace('%7E', '~')
Rob
2015-06-08, 23:51
(2015-06-08, 22:02)rob_webset Wrote: [ -> ]This endpoint is an URI. You have to call it url encoded(2015-06-08, 18:57)bromix Wrote: [ -> ](2015-06-08, 17:25)capfuturo Wrote: [ -> ]Hello Bromix, I am testing Rob's support for YouTube add-on in VideoExtras, so far so good and with room for improvement (mainly handling a way to better exiting youtube back into VideoExtras and the dowload option, the later I believe is being taken care of in your to do list.
Done
UPD: code cleaning
Hi bromix,
Code:20:55:10 T:2968 NOTICE: [plugin.video.vimeo] Running: Vimeo (4.1.2) on Helix (14.0) with Python 2.7.8
Rob
2015-06-09, 07:05
(2015-06-08, 23:51)bromix Wrote: [ -> ]This endpoint is an URI. You have to call it url encoded
Thanks for spotting that - I had indeed forgotten to encode that - now calling urllib.quote_plus() to encode the string before sending it, and that results in the name:
plugin://plugin.video.vimeo/search/?q=The%20Breakfast%20Club%20%c3%a9%20Extras
I hope that's OK (I'm rubbish at this encoding stuff!)
But I still get the error:
06:00:39 T:5132 DEBUG: [plugin.video.vimeo] Starting Kodion framework by bromix...
06:00:39 T:5132 NOTICE: [plugin.video.vimeo] Running: Vimeo (4.1.2) on Helix (14.0) with Python 2.7.8
06:00:39 T:5132 DEBUG: [plugin.video.vimeo] Path: "/search/
06:00:39 T:5132 DEBUG: [plugin.video.vimeo] Params: "{'q': u'The Breakfast Club \xe9 Extras'}"
06:00:39 T:5132 DEBUG: [plugin.video.vimeo] Setting content-type: "episodes" for "/search/"
06:00:39 T:5132 ERROR: C:\XBMC\Kodi-14-Helix\system\python\Lib\urllib.py:1288: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
06:00:39 T:5132 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\default.py", line 7, in <module>
runner.run(__provider__)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\kodion\runner.py", line 32, in run
__RUNNER__.run(provider, context)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\kodion\impl\xbmc\xbmc_runner.py", line 23, in run
results = provider.navigate(context)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\kodion\abstract_provider.py", line 123, in navigate
result = method(context, re_match)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\kodion\register_provider_path.py", line 12, in wrapper
return func(*args, **kwargs)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\provider.py", line 116, in endpoint_search
return self.on_search(query, context, re_match)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\provider.py", line 125, in on_search
xml = client.search(query=search_text, page=page)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\client.py", line 66, in search
post_data=post_data)
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\client.py", line 516, in _perform_v2_request
_headers.update(self._create_authorization(url, method, oauth_parms))
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\client.py", line 486, in _create_authorization
base_string += _percent_encode(_normalize_parameters(all_params))
File "C:\XBMC\Kodi-14-Helix\portable_data\addons\plugin.video.vimeo\resources\lib\vimeo\client.py", line 463, in _normalize_parameters
list_of_params.append('%s=%s' % (key, _percent_encode(value)))
File "C:\XBMC\Kodi-14-Helix\system\python\Lib\urllib.py", line 1293, in quote_plus
s = quote(s, safe + ' ')
File "C:\XBMC\Kodi-14-Helix\system\python\Lib\urllib.py", line 1288, in quote
KeyError: u'\xe9'
06:00:39 T:5132 INFO: Python script stopped
06:00:39 T:5132 DEBUG: Thread LanguageInvoker 5132 terminating
06:00:39 T:6012 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
06:00:39 T:3180 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
06:00:39 T:6012 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.vimeo/search/?q=The%20Breakfast%20Club%20%c3%a9%20Extras
06:00:39 T:6012 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vimeo/search/?q=The%20Breakfast%20Club%20%c3%a9%20Extras) failed
Rob
2015-06-09, 08:18
(2015-06-09, 07:05)rob_webset Wrote: [ -> ](2015-06-08, 23:51)bromix Wrote: [ -> ]This endpoint is an URI. You have to call it url encoded
Code:plugin://plugin.video.vimeo/search/?q=The%20Breakfast%20Club%20%c3%a9%20Extras
Code:...
Rob
Can you provide me with original search (without encoding) maybe urllib.quote() will do the trick. Also please provide logs via pastebin.com or similar services
2015-06-09, 08:40
(2015-06-09, 08:18)bromix Wrote: [ -> ]Can you provide me with original search (without encoding) maybe urllib.quote() will do the trick. Also please provide logs via pastebin.com or similar services
So we have the following:
Which came from the original title
The Breakfast Club é Extras
(I know it's not the normal title - but I editted it for testing)
Which was encoded as:
Changing between urllib.quote() and urllib.quote_plus() didn't seem to stop the error.
Rob
2015-06-09, 09:21
(2015-06-09, 08:40)rob_webset Wrote: [ -> ](2015-06-09, 08:18)bromix Wrote: [ -> ]Can you provide me with original search (without encoding) maybe urllib.quote() will do the trick. Also please provide logs via pastebin.com or similar services
Code:[plugin.video.vimeo] Params: "{'q': u'The Breakfast Club \xe9 Extras'}"
Code:The Breakfast Club é Extras
Rob
okay...I look into it after work
