Fixed error when image for channel/stream is not present:
Link is in the first message.
Hello Everyone,
I'm very new to this stuff, I am very interested in using this plug-in to watch some streams on Hitbox.tv. How do I use this in Kodi? Any help would be appreciated.
Thank You all and keep up the great work.
FinFam
Hello Everyone,
I figured it out
Thank you for this! I was looking for a Hitbox addon, and it works great!
If you could add a way to list only streams that a certain user follows (like the Twitch addon does), it would be perfect!
Also, if anyone else is not sure how to install it, here's a guide:
http://kodi.wiki/view/Add-on_manager#How...a_ZIP_file
Added "follows" support. Enter user which you follow in addon settings.
Added VODs support for user which you follow
Wow, awesome! Thanks again!
many many thanks for this plugin! it works perfect, it's superb
Hi!
I have two questions for you:
1. This AddOn currently lacks a licence. Would you mind publishing it under a GPL licence?
2. In case you agree with the first question, how about creating a GitHub repository for this AddOn? There's a few things I'd like to contribute.
If you have any questions feel free to PM me.
Hi culprit,
I am sorry, I am too lazy to do all that stuff.
You can do with addon whatever you want, I do not have any problems with that
Please share your improvements with community
Okay, so I started development on
https://github.com/liquex/plugin.video.hitbox
Feel free to join me there. I separated the Hitbox API from the actual plugin so either part can easily be modified and tested on its own. The API is working but incomplete, for example VODs are missing. The plugin currently isn't functional at all.
My aim is to make it as similar as possible to the Twitch plugin, so they feel about the same when using them.
Great!
Please let me know when it's functional and I'll update first post in this thread, or you can create new thread...
Just found this. It's great. Thanks!
