2018-04-09, 09:23
I never use streams, so I can't help. You probably just the first to find this behavior, there have been some very big changes lately and some fallout is expected. So please check, why it's (not) happening.
(2018-04-09, 09:23)Razze Wrote: [ -> ]I never use streams, so I can't help. You probably just the first to find this behavior, there have been some very big changes lately and some fallout is expected. So please check, why it's (not) happening.Well in what appears to be coincidental and very weird timing - the issue now seems to be no more....
01:34:59.309 T:25184 INFO: initializing python engine.
01:34:59.309 T:25184 DEBUG: CPythonInvoker(219, C:\Users\Mario\AppData\Roaming\Kodi\addons\script.trakt\defaultscript.py): start processing
01:34:59.320 T:23516 DEBUG: [script.trakt] resources.lib.service: [traktPlayer] onPlayBackEnded() - 0
01:34:59.369 T:23516 DEBUG: [script.trakt] resources.lib.service: Queuing for dispatch: {'action': 'ended'}
01:34:59.457 T:23516 DEBUG: [script.trakt] resources.lib.service: Queued dispatch: {u'action': u'ended'}
01:34:59.458 T:23516 DEBUG: [script.trakt] resources.lib.service: Dispatch: {u'action': u'ended'}
01:34:59.459 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: playbackEnded()
01:34:59.462 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: scrobble()
01:34:59.464 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: scrobble sending show object: {'ids': {u'tmdb': 18014, u'tvdb': 97731, u'trakt': 17933, u'imdb': u'tt1430587', u'tvrage': 22690, u'slug': u'tosh-0'}}
01:34:59.465 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: scrobble sending episode object: {u'season': 6, 'user': {'ratings': {}}, u'ids': {u'tvdb': 4834166, u'tmdb': 1007168, u'imdb': u'tt3627326', u'tvrage': 0, u'trakt': 568965}, u'number': 8, u'title': u'Comedian Daniel Songer'}
01:35:00.041 T:23516 DEBUG: [script.trakt] requests.packages.urllib3.connectionpool: https://api.trakt.tv:443 "POST /scrobble/stop HTTP/1.1" 201 None
01:35:00.106 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: [traktPlayer] Setting is enabled to try secondary show title, if necessary.
01:35:00.107 T:23516 DEBUG: [script.trakt] resources.lib.scrobbler: Scrobble response: {u'sharing': {u'tumblr': False, u'twitter': False, u'facebook': False}, u'episode': {u'season': 6, u'ids': {u'tvdb': 4834166, u'tmdb': 1007168, u'imdb': u'tt3627326', u'tvrage': 0, u'trakt': 568965}, u'number': 8, u'title': u'Comedian Daniel Songer'}, u'show': {u'year': 2009, u'ids': {u'tmdb': 18014, u'tvdb': 97731, u'trakt': 17933, u'imdb': u'tt1430587', u'tvrage': 22690, u'slug': u'tosh-0'}, u'title': u'Tosh.0'}, u'action': u'scrobble', u'progress': 99.9897627612248, u'id': 3535722861L}
01:35:00.107 T:23516 DEBUG: [script.trakt] resources.lib.rating: Rating Check called for 'episode'
01:35:00.108 T:23516 DEBUG: [script.trakt] resources.lib.rating: Summary Info {u'season': 6, 'user': {'ratings': {}}, u'ids': {u'tvdb': 4834166, u'tmdb': 1007168, u'imdb': u'tt3627326', u'tvrage': 0, u'trakt': 568965}, u'number': 8, u'title': u'Comedian Daniel Songer'}
01:35:00.123 T:17956 DEBUG: ------ Window Init (C:\Users\Mario\AppData\Roaming\Kodi\addons\script.trakt\resources\skins\Default\720p\script-trakt-RatingDialog.xml) ------
01:35:00.123 T:17956 INFO: Loading skin file: C:\Users\Mario\AppData\Roaming\Kodi\addons\script.trakt\resources\skins\Default\720p\script-trakt-RatingDialog.xml, load type: LOAD_ON_GUI_INIT
(2018-04-10, 12:11)Razze Wrote: [ -> ]Glad to hearActually now it's not working again - talk about driving me crazy and nothing has changed since it started "working" again last night.
23:41:47.126 T:10836 DEBUG: [script.trakt] resources.lib.service: Queued dispatch: {u'action': u'manualSync', u'silent': True, u'library': u'all'}
23:41:47.126 T:10836 DEBUG: [script.trakt] resources.lib.service: Dispatch: {u'action': u'manualSync', u'silent': True, u'library': u'all'}
23:41:47.126 T:10836 DEBUG: [script.trakt] resources.lib.service: Performing a manual sync.
23:41:47.127 T:10040 DEBUG: [script.trakt] resources.lib.sync: Sync is being run silently.
23:41:47.128 T:10040 DEBUG: [script.trakt] resources.lib.sync: Starting synchronization with Trakt.tv
23:41:47.128 T:10040 DEBUG: [script.trakt] resources.lib.syncMovies: [Movies Sync] Getting movie data from Kodi
(2018-04-11, 09:27)Razze Wrote: [ -> ]Synching is weird, are you sure you have no custom bindings done for that? It only happens if it's directly cal, which we don't do in the plugin - besides when you start the script manually from the options.I don't think I have any custom bindings set for Trakt to sync "manually".
Haven't updated my machine in the last few days, will try to do later and see if I can replicate. Wouldn't be surprised if something goes wrong, as we are changing pretty big stuff at the minute.
(2018-04-12, 19:25)mgonzales Wrote: [ -> ]should be manualSync(2018-04-11, 09:27)Razze Wrote: [ -> ]Synching is weird, are you sure you have no custom bindings done for that? It only happens if it's directly cal, which we don't do in the plugin - besides when you start the script manually from the options.I don't think I have any custom bindings set for Trakt to sync "manually".
I can start looking for something that does unbeknownst to me - what is the call to the Trakt add on for a manual sync so I can start grep and awk'ing for such a troublemaker.
M
(2018-04-12, 20:23)melons2 Wrote: [ -> ]I must have changed a setting or something. I used to watch a TV episode or a movie and at the end the Trakt rating bar would appear and allow me to rate what I had just watched. This quit working.....why or what do I adjust to get this feature back?
(2018-04-12, 20:30)Supersilver Wrote: [ -> ]Hey Razze, is there any reason that Trakt scrobbles Tv shows fine in Embycon but not movies, or is it a fluke that it's even able to scrobble Tv shows, hope you can help I can provide logs if needed.
(2018-04-12, 21:40)Razze Wrote: [ -> ]I am using version 3.2.0 of the addon but I get the behavior in both KODI 17.6 and 18 alpha or nightly(2018-04-12, 19:25)mgonzales Wrote: [ -> ]should be manualSync(2018-04-11, 09:27)Razze Wrote: [ -> ]Synching is weird, are you sure you have no custom bindings done for that? It only happens if it's directly cal, which we don't do in the plugin - besides when you start the script manually from the options.I don't think I have any custom bindings set for Trakt to sync "manually".
M
Which version are you using?
No idea about embycon, but which version are you using?
(2018-04-11, 09:27)Razze Wrote: [ -> ]No idea about embycon, but which version are you using?
(2018-04-13, 09:31)Razze Wrote: [ -> ]Sorry which kodi versionOh sorry [emoji14] Kodi 17.6 Krypton
(2018-04-05, 23:53)Razze Wrote: [ -> ](2018-04-05, 09:48)HydroDiOxide Wrote: [ -> ]Hi,Your six addon seems borked, maybe you got some funny repos installed? Anyway, reinstall six hopefully from the official repo.
I love the add-on. It's working fine for me on my Libre-elec and linux boxes. However, in windows the add-on won't start. I'm getting a 'Trakt error' notification when starting Kodi, pointing to the log. Below is the error from the log:
https://paste.ubuntu.com/p/3BFYc3V48M/
Any idea what might be going wrong?
(2018-04-12, 21:40)Razze Wrote: [ -> ](2018-04-12, 19:25)mgonzales Wrote: [ -> ]should be manualSync(2018-04-11, 09:27)Razze Wrote: [ -> ]Synching is weird, are you sure you have no custom bindings done for that? It only happens if it's directly cal, which we don't do in the plugin - besides when you start the script manually from the options.I don't think I have any custom bindings set for Trakt to sync "manually".
M
now I can move past this obsessive episode and hobble along until normality returns hehepython:
# -*- coding: utf-8 -*-
import xbmc
def __getMediaType():
if xbmc.getCondVisibility('Container.Content(tvshows)'):
return "show"
elif xbmc.getCondVisibility('Container.Content(seasons)'):
return "season"
elif xbmc.getCondVisibility('Container.Content(episodes)'):
return "episode"
elif xbmc.getCondVisibility('Container.Content(movies)'):
return "movie"
else:
return None
if not xbmc.getInfoLabel("ListItem.UserRating"):
xbmc.executebuiltin("RunScript(script.trakt,action=rate,media_type=%s,dbid=%s)" % (__getMediaType(), xbmc.getInfoLabel("ListItem.DBID")))
