2019-12-22, 23:47
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136
2019-12-23, 03:29
I have updated, restarted, cleared cache, triple checked settings and the rating dialogue window does not pop up after watching movies anymore in any kodi app.
I do updates from the official kodi repo
I checked my login on tract.tv and it reports back movies I've watched but no rating dialogue all of a sudden.
Any help would be appreciated.
2019-12-23, 09:55
Trakt for emby is also having problems, I suspect the problem is on Trakt' s side.
2019-12-25, 16:56
(2019-10-31, 06:30)NavySealsGuy Wrote: [ -> ]I had previously commented that some new movies that I added to my library were not getting picked up by the trakt sync. I have figured out that the problem is new movies with the same title as other movies are not being synced correctly. For example, Dumbo, Aladdin, Casino Royale, The Mummy, and so on. Importantly, this wasn't an issue with the original trakt/library linking. Only for new movies added after the initial sync. It isn't a huge issue now that I can easily identify which movies were not added, but I figured I would mention it in case someone else runs into the problem.Have you noticed if it's the same for series?
Cause I have a problem with the series Shameless, that has a UK original with the same name, that I just now realized hadn't synced its watch state since I began watching the latest season a month ago. And further more all previous 9 seasons has been removed from my collection.
At the same time other series and movies sync as expected.
2019-12-27, 08:14
(2019-12-25, 16:56)inzzzomnia Wrote: [ -> ]No, I don't have any series with the same titles in my collection at the moment.(2019-10-31, 06:30)NavySealsGuy Wrote: [ -> ]I had previously commented that some new movies that I added to my library were not getting picked up by the trakt sync. I have figured out that the problem is new movies with the same title as other movies are not being synced correctly. For example, Dumbo, Aladdin, Casino Royale, The Mummy, and so on. Importantly, this wasn't an issue with the original trakt/library linking. Only for new movies added after the initial sync. It isn't a huge issue now that I can easily identify which movies were not added, but I figured I would mention it in case someone else runs into the problem.Have you noticed if it's the same for series?
2019-12-28, 23:57
Sam problem as the above, not updating at all. Started at 14.12.2019.
There is nothing in kodi.log even if debug mode is on.
2020-01-20, 00:58
I don't know whats wrong. My trakt addon automatically gives movies a 10 rating (it hurt so much when it gave The Twilight Saga that) as soon as I add it to the library. I have to go to the trakt website to correct the ratings. Doesn't do the same for episodes though.
2020-01-20, 05:53
(2020-01-20, 00:58)misterkoat Wrote: [ -> ]I don't know whats wrong. My trakt addon automatically gives movies a 10 rating (it hurt so much when it gave The Twilight Saga that) as soon as I add it to the library. I have to go to the trakt website to correct the ratings. Doesn't do the same for episodes though.One of the menus towards the end I think, in settings, lets you set default rating which is defaulted to a 6.
2020-01-21, 14:03
Hi. I have problems scrobbling TV Show "The Outsider" (2020). I run Kodi on my Android Box. Kodi (18.5 Git:20191116-37f51f6e63). Platform: Android ARM 32-bit. script.trakt v3.2.4.
Relevant fragment of the debug log: https://paste.kodi.tv/izohatehek.kodi
2020-01-29, 22:45
I've used the add-on for a while and it is great. From time to time though my watched statuses don't seem to go to Trakt (or to another Kodi). Even if I manually run the add-on, nothing. Eventually it always seems to come through, but I am wondering if there is something else I can try.
I was watching a series on one tv and the first 7 episodes synced to Trakt. On another TV (obviously all through Kodi) it showed no episodes watched. Trakt website showed 7 watched. I ran the add-on manually like 4 times. Still didn't sync watched episodes. I watched the 8th episode on the 2nd box. Never synced to Trakt website. Ran add-on manually many times.
Is running this on multiple Kodi boxes an issue? Is there something special that should be done?
I was thinking it could be specific series, but since it synced on one box that seems very unlikely.
2020-01-30, 18:17
(2020-01-29, 22:45)michaeljc70 Wrote: [ -> ]I've used the add-on for a while and it is great. From time to time though my watched statuses don't seem to go to Trakt (or to another Kodi). Even if I manually run the add-on, nothing. Eventually it always seems to come through, but I am wondering if there is something else I can try.
Now I feel stupid. Somehow this box lost its Trakt authorization and I didn't notice. All working now.
2020-02-06, 18:46
(2020-01-30, 18:17)michaeljc70 Wrote: [ -> ](2020-01-29, 22:45)michaeljc70 Wrote: [ -> ]I've used the add-on for a while and it is great. From time to time though my watched statuses don't seem to go to Trakt (or to another Kodi). Even if I manually run the add-on, nothing. Eventually it always seems to come through, but I am wondering if there is something else I can try.
It lost authorization again. I re-authorized it and it was gone 20 minutes later. Any idea what causes this? I have 3 Kodi boxes using the same account.
2020-02-16, 15:17
Never heard of that, been using my auth for like forever, but only with one device. Might be server side through, you would have to reach out to the trakt guys to find out.
2020-02-18, 13:33
@Razze
Someone (may be ronie as per https://github.com/xbmc/xbmc/issues/17326) released a newer version of script in the matrix repo and it refuses to install due to six dependency. As far as I know six is at 1.14.0
but the addon.xml of script.module.trakt in kodi Matrix repo is asking for 1.174.0 and is causing it to fail installing
Can you please fix it, thanks
<addon id="script.module.trakt"
name="trakt.py"
version="3.1.0.1"
provider-name="Dean Gardiner">
<requires>
<import addon="xbmc.python" version="3.0.0"/>
<import addon="script.module.requests" version="2.22.0"/>
<import addon="script.module.six" version="1.174.0"/>
<import addon="script.module.arrow" version="0.15.5.1"/>
</requires>
2020-02-18, 15:21
thanx for the heads-up!
it's indeed a typo i made when updating many script modules for matrix.
fix is on it's way: https://github.com/xbmc/repo-scripts/com...9ee3e40e84
