(2015-04-14, 02:48)jes0411 Wrote: [ -> ]I have same problem with beta 7 too.
I have it on kodi 14.2 on windows 10 x64
beta 7 seems to be working for myself and others so if you havent done so already try reinstalling and then restarting kodi, if you still have problems you may want to try removing the script.trakt directory in userdata/addon_data/ after uninstalling but before reinstalling
(2015-04-14, 02:48)jes0411 Wrote: [ -> ] (2015-04-14, 02:18)Razze Wrote: [ -> ] (2015-04-14, 01:35)RavRob Wrote: [ -> ]Mine was working on my Windows 7 last night but after a reboot it is no longer scrobbling. Same thing on my windows 8.1, not working after a reboot. Beta 6 using Isenguard Alpha 2 on both machines.
Yeah, beta 6 had problems with reading back the auth.
Just update to beta 7
It doesn't work until I close kodi and open it again after update to beta 7, then it works well.
(2015-04-14, 06:39)jes0411 Wrote: [ -> ] (2015-04-14, 02:48)jes0411 Wrote: [ -> ]I have same problem with beta 7 too.
yep, had to do that and enter a new pin, awesome quick implementation and fix of PIN authentication [WINKING FACE]
(2015-04-14, 07:42)Razze Wrote: [ -> ] (2015-04-14, 02:48)jes0411 Wrote: [ -> ] (2015-04-14, 02:18)Razze Wrote: [ -> ]Yeah, beta 6 had problems with reading back the auth.
Just post a log, please
An update to Beta 7 with reboot seemed to have done the trick. I had a message saying something to the effect of "invalid PIN" or something but it seemed to have fixed itself. Just in case I got another pin and entered it again. It now works great again.
Tx Razze
Closing kodi and opening it again solved it with beta 7, now it works.
where can I update to beta 7? i use the "dev" branch from github and it's beta 6
(2015-04-14, 23:12)j3rom3 Wrote: [ -> ]Hello,
I have a problem with this addon on openelec 5.0.8.
Trakt.tv don't connect at startup .
The logfile : http://xbmclogs.com/pm3chbdv5
Increase the startup delay to the max or/and set openelec to wait for network on startup
Razze or anyone else.
I have tried both installing trakt on a completely fresh 14.2 and a older 14.2 installation. On the 14.2 I was never able to get it to work. However, on my fresh 14.2 installation it worked once synching my watchlist and it no longer works now. Here is what I did when it worked.
Installed Kodi Helix 14.2
Added the Trakt add-on.
Inputted my credentials.
Restarted the system and installed my addons.
Inputted my Trakt credentials into a few addons.
- Trakt shows then showed up in my watchlist.
- Added more shows to my watch list on trakt.tv.
- Shows are no longer showing.
- Tried changing startup delay for trakt with no success or change in operation.
* Interesting to note as I watch shows on my other Genesis install it updates my watch history on Trakt.tv.
Here is my log file: URL:
http://txs.io/k11b
Any help would be greatly appreciated, thanks so much!
Please remove the forbidden addon from your post.
On spot problem, your logfile is useless. Please check the github repo for instructions
when you land on the new beta ( 6 was the last one I found )
and then you fire up "where to get my pin " the scan code is blocked by the configuration page
perhaps something can be done so the scan code and link goes in front of it just on that instance
Raps
(2015-04-19, 20:03)Rapsody10 Wrote: [ -> ]when you land on the new beta ( 6 was the last one I found )
Raps
Well the config window should close when you fire up the scan dialog (as I wasn't able to open both)
this is how I get it when i click it
perhaps gives you a better idea
hope it helps
Raps
(2015-04-19, 21:06)Rapsody10 Wrote: [ -> ]this is how I get it when i click it
hope it helps
Raps
Ah, that dialogue. I'll look into it.
