(2015-06-18, 22:29)Razze Wrote: [ -> ] (2015-06-18, 00:15)marhutchy Wrote: [ -> ] (2015-06-17, 18:57)Razze Wrote: [ -> ]Well when it happens without the addon, then it's probably a problem with the kodi version. You should seek help there.
Okay. I already am, but not getting much response from anyone.
But the other error is gone?
I haven't seen the error, but I got some advice to make some changes to my settings, so I'm just running in debugging mode without some add-ons enabled to see if my problem's fixed.
Will check that soon.
(2015-06-18, 21:05)Skank Wrote: [ -> ]@Razze
Trakt isnt working for me on android, kodi 15 beta 1 on himediaplayer with external player
Can you have a look at log to see whats wrong pls
http://xbmclogs.com/pkf7drvfv
That log has no data on the trakt addon, please check the readme on how to create logs.
https://github.com/Razzeee/script.trakt#...g-logfiles
Can you have a relook pls
http://xbmclogs.com/pdorof3pp
Skank
You must enable debug from within the Trakt addon as well for Razze to see what's going on.
Accidentally closed the thread, sorry to any who wanted to post.
Version 3.0.2 has been pushed and should show up on your kodi instances in the next days. More infos then.
(2015-06-23, 22:21)RavRob Wrote: [ -> ]@Skank
ah, from within trakt addon?
Will look again, thought it was turned on
Does anyone know why the Trak.TV addon stops prompting for rating after media playback if DSPlayer is enabled?
(2015-05-12, 13:52)Razze Wrote: [ -> ] (2015-05-11, 20:03)Andy L Wrote: [ -> ]I also had to type in a new PIN today after being prompted to enter one for the first time yesterday. Hoping for a fix - let me know if you need any information about my setup.
Yeah, would be very interesting. Are the other settings beeing saved?
(2015-05-12, 10:25)burekas Wrote: [ -> ] (2015-05-07, 09:52)Razze Wrote: [ -> ]Seems like your addon config got messed up, you might want to reinstall it. In the best case you also remove the addon data from your filesystem before reinstalling.
Should fix erverything your second point is just a follow up error of one not working
I removed the addon, also I deleted other files as you said, installed it again from a repo (Because the zip file from github gave me an error "Dependencies not met")
But nothing changed, the rating's popup showing up only after TV-Shows, but after Movies it's not working.
What to do?
I still have this problem.
Sometimes when I put low percent value the popup is shown but if I put the 70-75 it's not working.
I see you have version 3.0.2 but I get an error "dependency not met" when installed.
(2015-06-29, 11:56)Skank Wrote: [ -> ] (2015-06-27, 23:21)Razze Wrote: [ -> ] (2015-06-27, 20:53)Skank Wrote: [ -> ]Activated from inside trakt addon, got this log now.
Dont see anything new abou trakt but i do have an error
http://xbmclogs.com/pzmwmflqs
Are you sure that you have debug activated in kodi AND in the trakt addon?
See step 2 here http://kodi.wiki/view/Log_file/Easy
New log, 100% sure all is actived now
http://xbmclogs.com/pulk4uu9v
Well seems to be active, but have you watched anything or what was your error? just search for [script.trakt] and you will find what the addon did. In your case it only seems like you had the settings opend once.
