The only solution I have found is if you have the Kodi remote apps (Kore/Yatse for Android or Kodi Remote for iOS) is using the keyboards on those apps to type in the pin. Hope they fix the addon soon, because at the present time it is pretty much worthless if you don't have a keyboard.
(2015-07-08, 17:59)amcfarla Wrote: [ -> ]The only solution I have found is if you have the Kodi remote apps (Kore/Yatse for Android or Kodi Remote for iOS) is using the keyboards on those apps to type in the pin. Hope they fix the addon soon, because at the present time it is pretty much worthless if you don't have a keyboard.
The fix is actually waiting for approval from team kodi. It should be pushed soon.
(2015-07-08, 19:28)Razze Wrote: [ -> ] (2015-07-08, 17:59)amcfarla Wrote: [ -> ]The only solution I have found is if you have the Kodi remote apps (Kore/Yatse for Android or Kodi Remote for iOS) is using the keyboards on those apps to type in the pin. Hope they fix the addon soon, because at the present time it is pretty much worthless if you don't have a keyboard.
Cool, that is great to hear. Thanks for the update @
Razze
For the last few days i dont get the TV epsisodes scrobbled with the plugin, and i have to manually log in to trakt website and set the date and time that i watched something. This has become very frustrating very quick
Is this a general problem, or have i screwed something up
(2015-07-10, 14:17)therock003 Wrote: [ -> ]For the last few days i dont get the TV epsisodes scrobbled with the plugin, and i have to manually log in to trakt website and set the date and time that i watched something. This has become very frustrating very quick
Not that I know of.
If it doesn't get scrobbled when you watch it, first try to sync, via launching it, that will set the episodes as watched on trakt with the date that kodi has saved.
Yeah I am getting this also, I tried to manual sync but it won't sync the tv episodes only my movies. I did a fresh install of the add on made it worse, when I try to launch Trakt sync it takes about 5 minutes to come up also the same when trying to add an account when clicking the "how do I authorise" the pop up comes up about 5 minutes later.
edit: So updating to Isengard fixed the 5 minute delay for me, something strange in my set up. Still getting stuck here thou:
http://iforce.co.nz/i/xsru5xd4.d4c.png
(2015-05-07, 09:52)Razze Wrote: [ -> ] (2015-05-07, 09:45)burekas Wrote: [ -> ]BUGS:
1) Why when I watching movies it doesn't updates the Trakt site automatically?
I'm always need to run the Trakt's add-on manually in order to do that.
2) Why I don't get the rating popup anymore after watching? (Especially on Movies) and sending it to Trakt.
I checked the settings and everything configured well.
Thanks,
Seems like your addon config got messed up, you might want to reinstall it. In the best case you also remove the addon data from your filesystem before reinstalling.
Should fix erverything your second point is just a follow up error of one not working
Please Help.
These 2 problems occur only after movies (with TV-Shows everything is OK)
Why after watching a movie, the rating's popup window is not showing up, and why it is not sending the info to Trakt site as 'watched' and not mentioned in the history?
I have already uninstalled the previous version, removed the folders and then reinstalled it again (3.0.3)
The option of rating Movies is 'On' (also scrobbles)
Also "Added watched movies to Trakt" is 'On'.
Just if I'm launching the addon it sending the supposed info to Trakt.
(2015-07-15, 23:30)burekas Wrote: [ -> ] (2015-05-07, 09:52)Razze Wrote: [ -> ] (2015-05-07, 09:45)burekas Wrote: [ -> ]BUGS:
Thanks,
Please Help.
You might want to provide a logfile. See the first post for more infos on that.
Anything special about your setup? Custom player? Custom database? Anything?
I've been using Trakt for quite awhile now, but recently wondered if it is possible for it to scrobble shows watched through Kodi that are recorded via my WMC PVR? Is there any way to do this? I did try searching the forum, but 'PVR' is not a long enough search term, so I can't search the thread. Any insight would be greatly appreciated!
(2015-07-16, 01:36)Razze Wrote: [ -> ] (2015-07-15, 23:30)burekas Wrote: [ -> ] (2015-05-07, 09:52)Razze Wrote: [ -> ]Seems like your addon config got messed up, you might want to reinstall it. In the best case you also remove the addon data from your filesystem before reinstalling.
Please Help.
I didn't was on debug mode so I hope it will help.
I didn't see something strange there.
Here is the log file:
http://xbmclogs.com/p1lov43tk
Using the basic kodi player, Titan skin (But I think it was also with Confluence)
As I said it happens only with Movies.
As long as the pvr provides the needed data. But I haven't seen that working
(2015-07-16, 22:08)burekas Wrote: [ -> ] (2015-07-16, 01:36)Razze Wrote: [ -> ] (2015-07-15, 23:30)burekas Wrote: [ -> ]Please Help.
Here is the log file: http://xbmclogs.com/p1lov43tk
Can you activate debug in kodi and in the addon?
(2015-07-17, 02:04)Razze Wrote: [ -> ]As long as the pvr provides the needed data. But I haven't seen that working
(2015-07-16, 22:08)burekas Wrote: [ -> ] (2015-07-16, 01:36)Razze Wrote: [ -> ]You might want to provide a logfile. See the first post for more infos on that.
Kodi Debug (Enable) , Trakt Debug (Enable)
- It configured on 75% of video watchin to enable rating.
- The option of rating Movies is 'On' (also scrobbles)
- Also "Added watched movies to Trakt" is 'On'.
- I jumped in times for reaching the end of the video just for the debug (Didn't watch actually all the video)
Log file: Movies (Bug: No rating automatically after watching and no update to Trakt site)
http://xbmclogs.com/pfe4h9zx9
Log file: TV-Shows (Bug: No Bug)
http://xbmclogs.com/pa40ugeyk
Just to mention there is different scrappers between TV-Shows library to the Movies library.
Hoping it will help now.
(2015-07-17, 17:25)burekas Wrote: [ -> ] (2015-07-17, 02:04)Razze Wrote: [ -> ]As long as the pvr provides the needed data. But I haven't seen that working
(2015-07-16, 22:08)burekas Wrote: [ -> ]I didn't was on debug mode so I hope it will help.
Can you try the latest version from here?
https://github.com/Razzeee/script.trakt/tree/dev
That should fix it, please let me know.
(2015-07-17, 20:43)Razze Wrote: [ -> ] (2015-07-17, 17:25)burekas Wrote: [ -> ] (2015-07-17, 02:04)Razze Wrote: [ -> ]As long as the pvr provides the needed data. But I haven't seen that working
Log file: TV-Shows (Working good - There is no bug)
Still the same
I uninstalled trakt and removed all the folders manually.
Then Installed the Beta version. But there is no difference.
See Log files with the Beta version 3.0.4 of Trakt:
http://xbmclogs.com/pqoyubbld
* I also tried this with other scrapper. The same bug.
http://xbmclogs.com/p5hh7ntwk
What could be the reason?
