Hi
Yesterday i updated to stable Jarvis 16 (PC Windows) and ran Trakt, guess what... a couple of movies maybe 10 or so was posted as seen on my Facebook over and over again...
Takes for ages to remove them from my timeline.
I have trakt installed from the official kodi add-on repo... but it's stuck at version 3.07. Is that normal? I thought having it installed from the official kodi repo would always keep it up-to-date... now I see that I'm 4 releases behind. Which repo should I then install it from to always have the latest up-to-date release?
(2016-02-23, 20:07)ToddeSwe Wrote: [ -> ]Hi
I'll need a logfile to have any chance to know what's going on.
(2016-02-23, 20:10)kupony Wrote: [ -> ]I have trakt installed from the official kodi add-on repo... but it's stuck at version 3.07. Is that normal? I thought having it installed from the official kodi repo would always keep it up-to-date... now I see that I'm 4 releases behind. Which repo should I then install it from to always have the latest up-to-date release?
3.0.7 is correct, if your still on pre Jarvis. Only jarvis and beyond are able to run 3.1.X
(2016-02-23, 20:15)Razze Wrote: [ -> ] (2016-02-23, 20:07)ToddeSwe Wrote: [ -> ]Hi
How can i send them to you, i guess it's both the old and the current log you want since i have quited and started Kodi since yesterday.
(2016-02-23, 20:48)Razze Wrote: [ -> ] (2016-02-23, 20:24)ToddeSwe Wrote: [ -> ]Hi!
Here's the old one: http://pastebin.com/V0TZXXq2
And here's the new one from today: http://pastebin.com/YTqELgna
Hope they work...
They are both of no use, as the trakt addon isn't even mentiond in them. Probably due to debugging not being enabled.
Sorry for wasting your time. And now the Trakt addon is updated to the new one.
(2016-02-23, 20:52)ToddeSwe Wrote: [ -> ] (2016-02-23, 20:48)Razze Wrote: [ -> ] (2016-02-23, 20:24)ToddeSwe Wrote: [ -> ]Hi!
Hope they work...
Sorry for waisting your time. And now the Trakt addon is updated to the new one.
You not really wasted it
At least I know there might be a problem, if it ever comes up again.
Hi there I'm having a weird problem when syncing trakt not all the items in wishlist appear, and the movies on trakt don't show up in kodi.
I'm using kodi jarvis on minix neo h8 plus.
Thanks in advanced.
(2016-02-24, 17:11)devilzeyez Wrote: [ -> ]Hi there I'm having a weird problem when syncing trakt not all the items in wishlist appear, and the movies on trakt don't show up in kodi.
Thanks in advanced.
Your not talking about this addon.
(2016-02-24, 22:08)Razze Wrote: [ -> ] (2016-02-24, 17:11)devilzeyez Wrote: [ -> ]Hi there I'm having a weird problem when syncing trakt not all the items in wishlist appear, and the movies on trakt don't show up in kodi.
Thanks in advanced.
Nope I'm talking about this one which is the only trakt add on i have....
Isn't it right?
Thanks in advanced.
Yes, that's the right one. But it doesn't do anything with the "wishlist" yet. Any movies should not show up. This only syncs the watched/collected status from trakt onto your own collected movies that are already scraped in Kodi.
Anyone having issues that added movies are being automaticly rated as 1 (1 heart). Ive enabled in trakt settings addon enable rerating or something.
But when i go trakt.tv collection all my recently added movies have a 1 in the corner, and the rating weak sauce. Ive tried to look online and to see why this is happening, im not home atm, so cant post logs.
I've been using the trakt add-on for a long time now, but ever since upgrading from 3.0.7 > 3.1.1 now, I have the problem that when I finish watching a series.
after finishing it, it doesn't ask me to rate it any more. I can manually invoke the add-on and rate, that works fine. But, it used to pop-up after watching.
I checked my settings, and those all seem fine (also, I didn't change any settings). This is on Kodi 16.0.
Any idea what might be causing this or how I can fix it?
Cheers,
=7
