Sorry again for delay, been busy.
, got notification for updating trakt plugin. But all files in plugin folder have april 30 as date. Traktapi.py too. Your commit is from may 6th should it not have this date?
Did not work. No pop up no notification from trakt for successfully transmitting with the dev zip.
# -*- coding: utf-8 -*-
import xbmcaddon
import logging
import deviceAuthDialog
import time
from trakt import Trakt
from trakt.objects import Movie, Show
from utilities import findMovieMatchInList, findShowMatchInList, findEpisodeMatchInList, findSeasonMatchInList, createError
from kodiUtilities import getSetting, setSetting, notification, getString, checkAndConfigureProxy, getSettingAsInt
from sys import version_info
if version_info >= (2, 7):
from json import loads, dumps
else:
from simplejson import loads, dumps
# read settings
__addon__ = xbmcaddon.Addon('script.trakt')
__addonversion__ = __addon__.getAddonInfo('version')
logger = logging.getLogger(__name__)
class traktAPI(object):
__client_id = "d4161a7a106424551add171e5470112e4afdaf2438e6ef2fe0548edc75924868"
__client_secret = "b5fcd7cb5d9bb963784d11bbf8535bc0d25d46225016191eb48e50792d2155c0"
def __init__(self, force=False):
logger.debug("Initializing.")
proxyURL = checkAndConfigureProxy()
if proxyURL:
Trakt.http.proxies = {
'http': proxyURL,
'https': proxyURL
Trakt.configuration.defaults.app(
id=999
# Configure
Trakt.configuration.defaults.client(
id=self.__client_id,
secret=self.__client_secret
# Bind event
Trakt.on('oauth.token_refreshed', self.on_token_refreshed)
Trakt.configuration.defaults.oauth(
refresh=True
if getSetting('authorization') and not force:
self.authorization = loads(getSetting('authorization'))
else:
last_reminder = getSettingAsInt('last_reminder')
now = int(time.time())
if last_reminder >= 0 and last_reminder < now - (24 * 60 * 60) or force:
self.login()
def login(self):
# Request new device code
with Trakt.configuration.http(retry=True, timeout=90):
code = Trakt['oauth/device'].code()
# Construct device authentication poller
poller = Trakt['oauth/device'].poll(**code)\
.on('aborted', self.on_aborted)\
.on('authenticated', self.on_authenticated)\
.on('expired', self.on_expired)\
.on('poll', self.on_poll)
# Start polling for authentication token
poller.start(daemon=False)
logger.debug('Enter the code "%s" at %s to authenticate your account' % (
code.get('user_code'),
code.get('verification_url')
self.authDialog = deviceAuthDialog.DeviceAuthDialog('script-trakt-DeviceAuthDialog.xml', __addon__.getAddonInfo('path'),
code=code.get('user_code'), url=code.get('verification_url'))
self.authDialog.doModal()
del self.authDialog
def on_aborted(self):
"""Triggered when device authentication was aborted (either with `DeviceOAuthPoller.stop()`
or via the "poll" event)"""
logger.debug('Authentication aborted')
self.authDialog.close()
def on_authenticated(self, token):
"""Triggered when device authentication has been completed
:param token: Authentication token details
:type token: dict
self.authorization = token
setSetting('authorization', dumps(self.authorization))
logger.debug('Authentication complete: %r' % token)
notification(getString(32157), getString(32152), 3000)
self.updateUser()
def on_expired(self):
"""Triggered when the device authentication code has expired"""
logger.debug('Authentication expired')
def on_poll(self, callback):
"""Triggered before each poll
:param callback: Call with `True` to continue polling, or `False` to abort polling
:type callback: func
# Continue polling
callback(True)
def on_token_refreshed(self, response):
# OAuth token refreshed, save token for future calls
self.authorization = response
logger.debug('Token refreshed')
def updateUser(self):
user = self.getUser()
if user and 'user' in user:
setSetting('user', user['user']['username'])
else:
setSetting('user', '')
def scrobbleEpisode(self, show, episode, percent, status):
result = None
with Trakt.configuration.oauth.from_response(self.authorization):
if status == 'start':
with Trakt.configuration.http(retry=True):
result = Trakt['scrobble'].start(
show=show,
episode=episode,
progress=percent)
elif status == 'pause':
result = Trakt['scrobble'].pause(
show=show,
episode=episode,
progress=percent)
elif status == 'stop':
# don't retry on stop, this will cause multiple scrobbles
result = Trakt['scrobble'].stop(
show=show,
episode=episode,
progress=percent)
else:
logger.debug("scrobble() Bad scrobble status")
return result
def scrobbleMovie(self, movie, percent, status):
result = None
movie=movie,
progress=percent)
movie=movie,
progress=percent)
movie=movie,
progress=percent)
else:
return result
def getShowsCollected(self, shows):
Trakt['sync/collection'].shows(shows, exceptions=True)
return shows
def getMoviesCollected(self, movies):
Trakt['sync/collection'].movies(movies, exceptions=True)
return movies
def getShowsWatched(self, shows):
Trakt['sync/watched'].shows(shows, exceptions=True)
return shows
def getMoviesWatched(self, movies):
Trakt['sync/watched'].movies(movies, exceptions=True)
return movies
def getShowsRated(self, shows):
Trakt['sync/ratings'].shows(shows, exceptions=True)
return shows
def getEpisodesRated(self, shows):
Trakt['sync/ratings'].episodes(shows, exceptions=True)
return shows
def getMoviesRated(self, movies):
Trakt['sync/ratings'].movies(movies, exceptions=True)
return movies
def addToCollection(self, mediaObject):
result = Trakt['sync/collection'].add(mediaObject)
return result
def removeFromCollection(self, mediaObject):
result = Trakt['sync/collection'].remove(mediaObject)
return result
def addToHistory(self, mediaObject):
# don't try this call it may cause multiple watches
result = Trakt['sync/history'].add(mediaObject)
return result
def addToWatchlist(self, mediaObject):
result = Trakt['sync/watchlist'].add(mediaObject)
return result
def getShowRatingForUser(self, showId, idType='tvdb'):
ratings = {}
Trakt['sync/ratings'].shows(ratings)
return findShowMatchInList(showId, ratings, idType)
def getSeasonRatingForUser(self, showId, season, idType='tvdb'):
ratings = {}
Trakt['sync/ratings'].seasons(ratings)
return findSeasonMatchInList(showId, season, ratings, idType)
def getEpisodeRatingForUser(self, showId, season, episode, idType='tvdb'):
ratings = {}
Trakt['sync/ratings'].episodes(ratings)
return findEpisodeMatchInList(showId, season, episode, ratings, idType)
def getMovieRatingForUser(self, movieId, idType='imdb'):
ratings = {}
Trakt['sync/ratings'].movies(ratings)
return findMovieMatchInList(movieId, ratings, idType)
# Send a rating to Trakt as mediaObject so we can add the rating
def addRating(self, mediaObject):
result = Trakt['sync/ratings'].add(mediaObject)
return result
# Send a rating to Trakt as mediaObject so we can remove the rating
def removeRating(self, mediaObject):
result = Trakt['sync/ratings'].remove(mediaObject)
return result
def getMoviePlaybackProgress(self):
progressMovies = []
# Fetch playback
playback = Trakt['sync/playback'].movies(exceptions=True)
for _, item in playback.items():
if type(item) is Movie:
progressMovies.append(item)
return progressMovies
def getEpisodePlaybackProgress(self):
progressEpisodes = []
# Fetch playback
playback = Trakt['sync/playback'].episodes(exceptions=True)
if type(item) is Show:
progressEpisodes.append(item)
return progressEpisodes
def getMovieSummary(self, movieId):
return Trakt['movies'].get(movieId)
def getShowSummary(self, showId):
return Trakt['shows'].get(showId)
def getEpisodeSummary(self, showId, season, episode):
return Trakt['shows'].episode(showId, season, episode)
def getIdLookup(self, id, id_type):
result = Trakt['search'].lookup(id, id_type)
if result and not isinstance(result, list):
result = [result]
return result
def getUser(self):
result = Trakt['users/settings'].get()
return result
copied it with notepad++ to traktapi.py replaced old traktapi.py in C:\Users\XBMC\AppData\Roaming\Kodi\addons\script.trakt with your version. Trakt popped up with errors on startup.
One strange thing. On github it says there are 350 lines, in notepad++ there are only 348 lines after copying the code.
Ich mach was falsch Razze.
PS: I am a moron, I downloaded the wrong branch. I have to learn the proper use of github. Changed the branch to fix token refresh. I will try this zip and report back.
PPS: Adding the zip via kodi did not not work. So I manually copied all the files to the trakt script folder. Now everything works. I'm happy.
Kodi crashed after trakt.api submitted the data, but I am not sure if this was trakt related. Will monitor this, thx Razze.
