Full Version: ffmpeg errors and pixelation
I have Kodi with the Mediaportal PVR client and Mediaportal backend all on one PC. Watching fullscreen Live TV works ok until I open up a context menu where channel list shows with live tv in smaller window. The picture in the small window gets very bad pixelation to the point where it is unrecognisable. The same thing happens if I have a skin that lets me see live TV partially in the background while using menus. If I return to full screen live TV the picture is fine. The same problem happens with different skins. If I use the Mediportal frontend instead of Kodi I dont have this problem.
In the kodi log I see lots of these errors. Does anyone know I can to to troubleshoot and fix this problem?
12:16:16 T:1780 ERROR: ffmpeg[6F4]: [h264] decode_slice_header error
12:16:17 T:1780 ERROR: ffmpeg[6F4]: [h264] reference picture missing during reorder
12:16:17 T:1780 ERROR: ffmpeg[6F4]: [h264] Missing reference picture, default is 103829
12:16:17 T:1780 ERROR: ffmpeg[6F4]: [h264] Missing reference picture, default is 103836
12:16:17 T:1780 DEBUG: ffmpeg[6F4]: [h264] Found reference and non-reference fields in the same frame, which is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
12:16:17 T:1780 DEBUG: ffmpeg[6F4]: [h264] If you want to help, upload a sample of this file to ftp://upload.ffmpeg.org/incoming/ and contact the ffmpeg-devel mailing list. ([email protected])
Some more clues..
I tried running the kodi frontend on another PC with the same mediaportal backend. This system does not show the pixelation problems and none of those ffmpeg errors appear in the log.
I am wondering if the problem is related to the video card. The system showing the pixelation has a Radeon 5450 card with 512M video memory. The other system has Intel HD graphics built in.
I also noticed in debug mode that the system with problems is showing 100fps when the video is messed up as background to menu and 50fps when full screen viewing. The system that has no problem always show 50fps regardless of being background video or full screen viewing.
I think this problem is unrelated to the mediaportal pvr client. I reset the video settings to default and changed audio option in System Settings and now the frame rate does not jump to 100fps and the picture seems ok. I will keep an eye on it to check that it is fixed. In the process of working out what was wrong maybe I accidentally changed a setting that caused it.
Hi
Similar Problem here.
When I play my recordings and seek FF oder Rev the picture just freezes and audio continues. When I stop playback and go back and start playing the same recording again it mostly does no start instantly I have to try like 3 to 5 times until playback starts again.
Difference to your situation is I have no pixelation - my picture is either flawless or frozen :-)
The problem was NOT around with 14.0 and most likely with 14.1 - I would have noticed.
I noticed it 3 or 4 weeks ago and now have some time to look into it.
System:
AMD 10 6700 current Catalyst drivers which did not change since uuhm I dont know :-) - but nothing in the system or Kodi config has changed since end of January. Just the Kodi update to 14.2 in Feb.
Mediportal TV server is on the same machine.
What I already did with no success:
Updated Mediaportal Plugin from Margo to newest version.
Next up:
Test to see if the picture freezes on older recordings too
will keep posted in the next days
Ok
It happens with older files too.
Here is an extract of a log. I can't attach the 2nd lo because it's too long.
20:06:03 T:1012  NOTICE: Previous line repeats 1 times.
20:06:03 T:1012  NOTICE: Thread JobWorker start, auto delete: true
20:06:03 T:1012   ERROR: CCurlFile::Exists - Failed: Couldn't resolve host name(6) for http://www.google.com/
20:06:04 T:4652  NOTICE: CPowerManager::OnWake: Running resume jobs
20:06:04 T:4652  NOTICE: CPowerManager::OnWake: Restarting lirc
20:06:04 T:1756  NOTICE: Thread RemoteControl start, auto delete: false
20:06:04 T:4752  NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "1 - TX-NR3010 (3- AMD High Definition Audio Device)" seems to be not supported.
20:06:04 T:4752  NOTICE: Found 2 Lists of Devices
20:06:04 T:4752  NOTICE: Enumerated DIRECTSOUND devices:
20:06:04 T:4752  NOTICE:     Device 1
20:06:04 T:4752  NOTICE:         m_deviceName      : {220F291F-7693-48B0-8DC9-7AEA75259949}
20:06:04 T:4752  NOTICE:         m_displayName     : HDMI - 1 - TX-NR3010 (3- AMD High Definition Audio Device)
20:06:04 T:4752  NOTICE:         m_displayNameExtra: DIRECTSOUND: 1 - TX-NR3010 (3- AMD High Definition Audio Device)
20:06:04 T:4752  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
20:06:04 T:4752  NOTICE:         m_channels        : FL,FR
20:06:04 T:4752  NOTICE:         m_sampleRates     : 48000
20:06:04 T:4752  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
20:06:04 T:4752  NOTICE:     Device 2
20:06:04 T:4752  NOTICE:         m_deviceName      : default
20:06:04 T:4752  NOTICE:         m_displayName     : default
20:06:04 T:4752  NOTICE: Enumerated WASAPI devices:
20:06:04 T:4752  NOTICE:         m_displayNameExtra: WASAPI: 1 - TX-NR3010 (3- AMD High Definition Audio Device)
20:06:04 T:4752  NOTICE:         m_channels        : FL,FR,FC,LFE,SL,SR,BL,BR
20:06:04 T:4752  NOTICE:         m_sampleRates     : 192000,176400,96000,88200,48000,44100,32000
20:06:04 T:4752  NOTICE:         m_dataFormats     : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
20:06:04 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:06:04 T:4852  NOTICE: onNotification:System.OnWake:xbmc:null
20:06:04 T:5064  NOTICE: Previous line repeats 2 times.
20:06:04 T:5064   ERROR: AddOnLog: MediaPortal PVR Client: cEpg::ParseLine: Unable to convert original air date '' into date+time
20:06:14 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:06:17 T:4852  NOTICE: onNotification:GUI.OnScreensaverDeactivated:xbmc:{"shuttingdown":false}
20:06:18 T:3392  NOTICE: Previous line repeats 2 times.
20:06:18 T:3392  NOTICE: Thread LanguageInvoker start, auto delete: false
20:06:18 T:3392  NOTICE: -->Python Interpreter Initialized<--
20:06:18 T:1396  NOTICE: Thread JobWorker start, auto delete: true
20:06:18 T:3004  NOTICE: Thread LanguageInvoker start, auto delete: false
20:06:18 T:796  NOTICE: Thread JobWorker start, auto delete: true
20:06:18 T:3004  NOTICE: -->Python Interpreter Initialized<--
20:06:19 T:2640  NOTICE: Thread LanguageInvoker start, auto delete: false
20:06:19 T:2640  NOTICE: -->Python Interpreter Initialized<--
20:06:21 T:968  NOTICE: Thread BackgroundLoader start, auto delete: false
20:06:21 T:1396  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:06:24 T:4160  NOTICE: Thread BackgroundLoader start, auto delete: false
20:06:25 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:06:31 T:4652  NOTICE: DVDPlayer: Opening: F:\TV-Aufnahmen\Tatort\Tatort - Das Erste HD - 2014-08-10.ts
20:06:31 T:4652 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:06:31 T:4652  NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
20:06:31 T:4652  NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
20:06:31 T:1388  NOTICE: Thread DVDPlayer start, auto delete: false
20:06:31 T:1388  NOTICE: Creating InputStream
20:06:31 T:1388  NOTICE: Creating Demuxer
20:06:32 T:1388  NOTICE: Opening stream: 0 source: 256
20:06:32 T:1388  NOTICE: Creating video codec with codec id: 28
20:06:32 T:1388  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:06:32 T:1388  NOTICE: Creating video thread
20:06:32 T:1388  NOTICE: Opening stream: 5 source: 256
20:06:32 T:4280  NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:06:32 T:1388  NOTICE: Finding audio codec for: 86019
20:06:32 T:4280  NOTICE: running thread: video_thread
20:06:32 T:1388  NOTICE: Creating audio thread
20:06:32 T:1388  NOTICE: Opening stream: 4 source: 256
20:06:32 T:3036  NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:06:32 T:1388  NOTICE: Opening stream: 3 source: 256
20:06:32 T:3036  NOTICE: running thread: CDVDPlayerAudio::Process()
20:06:32 T:1388  NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
20:06:32 T:1388 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
20:06:32 T:1388  NOTICE: waiting for teletext data thread to exit
20:06:32 T:1388  NOTICE: Creating teletext data thread
20:06:32 T:3580  NOTICE: Thread DVDTeletextData start, auto delete: false
20:06:32 T:3580  NOTICE: running thread: CDVDTeletextData
20:06:32 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:32 T:3036  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
20:06:32 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:06:32 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:06:32 T:4852  NOTICE: emby 0 -> emby Service -> onPlayBackStarted : F:/TV-Aufnahmen/Tatort/Tatort - Das Erste HD - 2014-08-10.ts
20:06:32 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:32 T:4280  NOTICE:  fps: 50.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
20:06:32 T:4280  NOTICE: Display resolution ADJUST : 1920x1080@ 50.00 - Full Screen (16) (weight: 0.000)
20:06:32 T:4280  NOTICE: D3D: rendering method forced to DXVA processor
20:06:32 T:3040  NOTICE: Thread LanguageInvoker start, auto delete: false
20:06:32 T:3040  NOTICE: -->Python Interpreter Initialized<--
20:06:32 T:4852  NOTICE: onNotification:Player.OnPlay:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:06:32 T:4852  NOTICE: playlist onadd is called
20:06:32 T:3036   ERROR: CDVDPlayerAudio::DecodeFrame - Decode Error. Skipping audio packet (-1094995529)
20:06:35 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:35 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":403,"minutes":0,"seconds":33}}}
20:06:35 T:4280  NOTICE: Previous line repeats 2 times.
20:06:35 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:36 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":884,"minutes":1,"seconds":9}}}
20:06:37 T:4280  NOTICE: Previous line repeats 2 times.
20:06:37 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:37 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:37 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":884,"minutes":1,"seconds":9}}}
20:06:37 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:37 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":7,"minutes":1,"seconds":39}}}
20:06:38 T:4280  NOTICE: Previous line repeats 2 times.
20:06:38 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:38 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:38 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":91,"minutes":1,"seconds":39}}}
20:06:38 T:4852  NOTICE: Previous line repeats 8 times.
20:06:38 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":118,"minutes":2,"seconds":9}}}
20:06:38 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:39 T:4280  NOTICE: Previous line repeats 1 times.
20:06:39 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:39 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:39 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":724,"minutes":2,"seconds":41}}}
20:06:39 T:4280  NOTICE: Previous line repeats 2 times.
20:06:39 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:39 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":979,"minutes":3,"seconds":11}}}
20:06:39 T:4280 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:06:40 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:40 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":19,"minutes":3,"seconds":12}}}
20:06:41 T:4852  NOTICE: Previous line repeats 5 times.
20:06:41 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":764,"minutes":3,"seconds":42}}}
20:06:41 T:4280  NOTICE: Previous line repeats 2 times.
20:06:41 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:41 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:42 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":781,"minutes":4,"seconds":11}}}
20:06:42 T:4852  NOTICE: Previous line repeats 2 times.
20:06:42 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":881,"minutes":4,"seconds":11}}}
20:06:42 T:4280  NOTICE: Previous line repeats 2 times.
20:06:42 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:42 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:42 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:42 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:06:44 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:44 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:44 T:4852 WARNING: Previous line repeats 2 times.
20:06:44 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":324,"minutes":4,"seconds":45}}}
20:06:44 T:4280  NOTICE: Previous line repeats 2 times.
20:06:44 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:45 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":387,"minutes":5,"seconds":14}}}
20:06:45 T:4280  NOTICE: Previous line repeats 8 times.
20:06:45 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:45 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:45 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:48 T:4280  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:06:48 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:48 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":443,"minutes":5,"seconds":45}}}
20:06:48 T:4280  NOTICE: Previous line repeats 2 times.
20:06:48 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:48 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":8}}
20:06:49 T:4280  NOTICE: Previous line repeats 2 times.
20:06:49 T:4280 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:06:49 T:4280 WARNING: Previous line repeats 1 times.
20:06:49 T:4280   ERROR: DXVA::CDecoder::GetBuffer - no surface available - dec: 0, render: 78144352
20:06:49 T:4280   ERROR: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video returned failure
20:06:49 T:4280  NOTICE: DXVA::CDecoder::Close - closing decoder
20:06:49 T:4280  NOTICE: DXVA::Close - closing decoder context
20:06:49 T:4280   ERROR: CDecoder::Check - device didn't reset in reasonable time
20:06:49 T:4280 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:06:49 T:4280   ERROR: Unhandled exception in Process : Access violation at 0x77180fb2: Writing location 0x0000001c
20:06:50 T:4280  NOTICE: thread end: video_thread
20:06:50 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:06:52 T:4852  NOTICE: Previous line repeats 2 times.
20:06:52 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":29,"minutes":6,"seconds":30}}}
20:06:53 T:4852  NOTICE: Previous line repeats 2 times.
20:06:53 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":8}}
20:06:56 T:4852  NOTICE: Previous line repeats 2 times.
20:06:56 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:07:03 T:3036  NOTICE: Previous line repeats 2 times.
20:07:03 T:3036 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:07:14 T:4852  NOTICE: onNotification:Player.OnPause:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":0}}
20:07:16 T:4852  NOTICE: Previous line repeats 2 times.
20:07:16 T:4852  NOTICE: onNotification:Player.OnPlay:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:07:16 T:4852  NOTICE: playlist onadd is called
20:07:19 T:4852  NOTICE: onNotification:Player.OnPause:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":0}}
20:07:22 T:1472  NOTICE: Previous line repeats 2 times.
20:07:22 T:1472  NOTICE: Thread BackgroundLoader start, auto delete: false
20:07:22 T:4652  NOTICE: CDVDPlayer::CloseFile()
20:07:22 T:4652  NOTICE: DVDPlayer: waiting for threads to exit
20:07:22 T:1388  NOTICE: CDVDPlayer::OnExit()
20:07:22 T:1388  NOTICE: Closing stream player 1
20:07:22 T:1388  NOTICE: Waiting for audio thread to exit
20:07:22 T:3036  NOTICE: thread end: CDVDPlayerAudio::OnExit()
20:07:22 T:1388  NOTICE: Closing audio device
20:07:22 T:1388  NOTICE: Deleting audio codec
20:07:22 T:1388  NOTICE: Closing stream player 2
20:07:22 T:1388  NOTICE: waiting for video thread to exit
20:07:22 T:1388  NOTICE: deleting video codec
20:07:22 T:1388   ERROR: Unhandled exception in OnExit : Access violation at 0x77180fb2: Writing location 0x0000001c
20:07:22 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:07:22 T:4652  NOTICE: DVDPlayer: finished waiting
20:07:24 T:4652  NOTICE: CDVDPlayer::CloseFile()
20:07:24 T:4652  NOTICE: DVDPlayer: waiting for threads to exit
20:07:24 T:4652  NOTICE: DVDPlayer: finished waiting
20:07:24 T:4652  NOTICE: DVDPlayer: Opening: F:\TV-Aufnahmen\Tatort\Tatort - Das Erste HD - 2014-08-10.ts
20:07:24 T:4652  NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
20:07:24 T:4652  NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
20:07:24 T:3512  NOTICE: Thread DVDPlayer start, auto delete: false
20:07:24 T:3512  NOTICE: Creating InputStream
20:07:24 T:3512  NOTICE: Creating Demuxer
20:07:24 T:3512  NOTICE: Opening stream: 0 source: 256
20:07:24 T:3512  NOTICE: Creating video codec with codec id: 28
20:07:24 T:3512  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:07:24 T:3512   ERROR: Unhandled exception in Process : Access violation at 0x77180fb2: Writing location 0x0000001c
20:07:24 T:3512  NOTICE: CDVDPlayer::OnExit()
20:07:24 T:3512  NOTICE: DVDPlayer: eof, waiting for queues to empty
20:07:24 T:5092  NOTICE: Thread BackgroundLoader start, auto delete: false
20:07:24 T:4652  NOTICE: Previous line repeats 1 times.
20:07:24 T:4852  NOTICE: emby 1 -> emby Service -> onPlayBackStopped
20:07:24 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:07:24 T:4852  NOTICE: onNotification:Player.OnStop:xbmc:{"end":false,"item":{"title":"Tatort - Ein neues Leben","type":"movie"}}
20:07:26 T:3580  NOTICE: Previous line repeats 2 times.
20:07:26 T:3580  NOTICE: thread end: data_thread
20:07:26 T:5088  NOTICE: Thread BackgroundLoader start, auto delete: false
20:07:27 T:4652  NOTICE: DVDPlayer: Opening: F:\TV-Aufnahmen\Tatort\Tatort - Das Erste HD - 2014-08-10.ts
20:07:27 T:4652 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:07:27 T:4652  NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
20:07:27 T:4652  NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
20:07:27 T:704  NOTICE: Thread DVDPlayer start, auto delete: false
20:07:27 T:704  NOTICE: Creating InputStream
20:07:27 T:704  NOTICE: Creating Demuxer
20:07:27 T:704  NOTICE: Opening stream: 0 source: 256
20:07:27 T:704  NOTICE: Creating video codec with codec id: 28
20:07:27 T:704  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:07:27 T:704  NOTICE: Creating video thread
20:07:27 T:704  NOTICE: Opening stream: 5 source: 256
20:07:27 T:704  NOTICE: Finding audio codec for: 86019
20:07:27 T:328  NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:07:27 T:328  NOTICE: running thread: video_thread
20:07:27 T:704  NOTICE: Creating audio thread
20:07:27 T:704  NOTICE: Opening stream: 4 source: 256
20:07:27 T:4256  NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:07:27 T:704  NOTICE: Opening stream: 3 source: 256
20:07:27 T:704  NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
20:07:27 T:4256  NOTICE: running thread: CDVDPlayerAudio::Process()
20:07:27 T:704 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
20:07:27 T:704  NOTICE: waiting for teletext data thread to exit
20:07:27 T:704  NOTICE: Creating teletext data thread
20:07:27 T:4660  NOTICE: Thread DVDTeletextData start, auto delete: false
20:07:27 T:4660  NOTICE: running thread: CDVDTeletextData
20:07:28 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:07:28 T:4852  NOTICE: emby 0 -> emby Service -> onPlayBackStarted : F:/TV-Aufnahmen/Tatort/Tatort - Das Erste HD - 2014-08-10.ts
20:07:28 T:704  NOTICE: Opening stream: 0 source: 256
20:07:28 T:704  NOTICE: Creating video codec with codec id: 28
20:07:28 T:704  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:07:28 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:28 T:4256  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
20:07:28 T:4852  NOTICE: onNotification:Player.OnPlay:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:07:28 T:4852  NOTICE: playlist onadd is called
20:07:28 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:07:28 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:28 T:328  NOTICE:  fps: 50.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
20:07:28 T:328  NOTICE: Display resolution ADJUST : 1920x1080@ 50.00 - Full Screen (16) (weight: 0.000)
20:07:28 T:328  NOTICE: D3D: rendering method forced to DXVA processor
20:07:28 T:4336  NOTICE: Thread LanguageInvoker start, auto delete: false
20:07:28 T:704  NOTICE: Opening stream: 5 source: 256
20:07:28 T:704  NOTICE: Finding audio codec for: 86019
20:07:28 T:4336  NOTICE: -->Python Interpreter Initialized<--
20:07:32 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:32 T:4256  NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
20:07:32 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":343,"minutes":7,"seconds":43}}}
20:07:32 T:4756  NOTICE: Previous line repeats 2 times.
20:07:32 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:07:32 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:35 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":324,"minutes":8,"seconds":14}}}
20:07:35 T:328  NOTICE: Previous line repeats 2 times.
20:07:35 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:35 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:35 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":8}}
20:07:36 T:328  NOTICE: Previous line repeats 2 times.
20:07:36 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:07:36 T:328 WARNING: Previous line repeats 88 times.
20:07:36 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:37 T:328  NOTICE: Previous line repeats 1 times.
20:07:37 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:38 T:328  NOTICE: Previous line repeats 1 times.
20:07:38 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:07:39 T:4852 WARNING: Previous line repeats 51 times.
20:07:39 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:07:39 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:07:39 T:4256 WARNING: Previous line repeats 9 times.
20:07:39 T:4256 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:07:39 T:328 WARNING: Previous line repeats 1 times.
20:07:39 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:39 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:40 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:07:41 T:4256 WARNING: Previous line repeats 48 times.
20:07:41 T:4256 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:07:41 T:328 WARNING: Previous line repeats 2 times.
20:07:41 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:07:41 T:4256 WARNING: Previous line repeats 2 times.
20:07:41 T:328 WARNING: Previous line repeats 5 times.
20:07:41 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:41 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:42 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:07:46 T:328  NOTICE: Previous line repeats 2 times.
20:07:46 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:46 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:46 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":464,"minutes":9,"seconds":41}}}
20:07:46 T:4852  NOTICE: Previous line repeats 2 times.
20:07:46 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":611,"minutes":10,"seconds":11}}}
20:07:46 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":664,"minutes":10,"seconds":11}}}
20:07:47 T:328  NOTICE: Previous line repeats 5 times.
20:07:47 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:47 T:328 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:07:47 T:328 WARNING: Previous line repeats 1 times.
20:07:47 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:47 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":838,"minutes":10,"seconds":40}}}
20:07:47 T:328  NOTICE: Previous line repeats 2 times.
20:07:53 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:54 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":263,"minutes":11,"seconds":16}}}
20:07:54 T:328  NOTICE: Previous line repeats 2 times.
20:07:54 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:54 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":625,"minutes":11,"seconds":50}}}
20:07:54 T:4852  NOTICE: Previous line repeats 2 times.
20:07:54 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":704,"minutes":11,"seconds":50}}}
20:07:55 T:328  NOTICE: Previous line repeats 5 times.
20:07:55 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:07:55 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:55 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":372,"minutes":12,"seconds":20}}}
20:07:56 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":372,"minutes":12,"seconds":20}}}
20:07:56 T:328  NOTICE: Previous line repeats 2 times.
20:07:56 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:07:56 T:328 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:08:00 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:08:00 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":843,"minutes":12,"seconds":53}}}
20:08:00 T:328  NOTICE: Previous line repeats 2 times.
20:08:00 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:08:01 T:4852  NOTICE: onNotification:Player.OnSeek:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":30},"speed":1,"time":{"hours":0,"milliseconds":524,"minutes":13,"seconds":29}}}
20:08:02 T:328  NOTICE: Previous line repeats 5 times.
20:08:02 T:328  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
20:08:02 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":8}}
20:08:02 T:328  NOTICE: Previous line repeats 2 times.
20:08:02 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:08:02 T:328  NOTICE: Previous line repeats 1 times.
20:08:03 T:328   ERROR: DXVA::CDecoder::GetBuffer - no surface available - dec: 1, render: 78144352
20:08:03 T:328   ERROR: CDVDVideoCodecFFmpeg::Decode - avcodec_decode_video returned failure
20:08:03 T:328  NOTICE: DXVA::CDecoder::Close - closing decoder
20:08:03 T:328  NOTICE: DXVA::Close - closing decoder context
20:08:03 T:328   ERROR: CDecoder::Check - device didn't reset in reasonable time
20:08:03 T:328 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
20:08:04 T:328 WARNING: Previous line repeats 2 times.
20:08:04 T:328   ERROR: Unhandled exception in Process : Access violation at 0x77180fb2: Writing location 0x0000001c
20:08:04 T:328  NOTICE: thread end: video_thread
20:08:06 T:4852  NOTICE: onNotification:Player.OnSpeedChanged:xbmc:{"item":{"title":"Tatort - Ein neues Leben","type":"movie"},"player":{"playerid":-1,"speed":1}}
20:08:13 T:4256  NOTICE: Previous line repeats 2 times.
20:08:13 T:4256 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:08:27 T:4596  NOTICE: Thread BackgroundLoader start, auto delete: false
20:08:27 T:4652  NOTICE: CDVDPlayer::CloseFile()
20:08:27 T:4652  NOTICE: DVDPlayer: waiting for threads to exit
20:08:27 T:704  NOTICE: CDVDPlayer::OnExit()
20:08:27 T:704  NOTICE: Closing stream player 1
20:08:27 T:704  NOTICE: Waiting for audio thread to exit
20:08:27 T:4256  NOTICE: thread end: CDVDPlayerAudio::OnExit()
20:08:27 T:704  NOTICE: Closing audio device
20:08:27 T:704  NOTICE: Deleting audio codec
20:08:27 T:704  NOTICE: Closing stream player 2
20:08:27 T:704  NOTICE: waiting for video thread to exit
20:08:27 T:704  NOTICE: deleting video codec
20:08:27 T:704   ERROR: Unhandled exception in OnExit : Access violation at 0x77180fb2: Writing location 0x0000001c
20:08:27 T:4756   ERROR: CAESinkWASAPI::InitializeExclusive: IsFormatSupported failed (AUDCLNT_E_UNSUPPORTED_FORMAT) - trying to find a compatible format
20:08:27 T:4652  NOTICE: DVDPlayer: finished waiting
20:08:30 T:2444  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:30 T:2444  NOTICE: Previous line repeats 1 times.
20:08:30 T:2444  NOTICE: -->Python Interpreter Initialized<--
20:08:30 T:3528  NOTICE: Previous line repeats 1 times.
20:08:30 T:3528  NOTICE: Thread FileCache start, auto delete: false
20:08:31 T:4356  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:31 T:4356  NOTICE: -->Python Interpreter Initialized<--
20:08:31 T:2676  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:31 T:2676  NOTICE: -->Python Interpreter Initialized<--
20:08:31 T:3544  NOTICE: Thread JobWorker start, auto delete: true
20:08:32 T:4976  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:32 T:4976  NOTICE: -->Python Interpreter Initialized<--
20:08:33 T:3796  NOTICE: Thread FileCache start, auto delete: false
20:08:34 T:680  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:34 T:680  NOTICE: -->Python Interpreter Initialized<--
20:08:37 T:4652 WARNING: Trying to add unsupported control type 1
20:08:37 T:3748  NOTICE: Thread BackgroundLoader start, auto delete: false
20:08:38 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:08:44 T:3860  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:44 T:3860  NOTICE: Previous line repeats 1 times.
20:08:44 T:3860  NOTICE: -->Python Interpreter Initialized<--
20:08:44 T:1644  NOTICE: Previous line repeats 1 times.
20:08:44 T:1644  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:44 T:1644  NOTICE: -->Python Interpreter Initialized<--
20:08:46 T:1264  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:46 T:1264  NOTICE: -->Python Interpreter Initialized<--
20:08:48 T:2004  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:48 T:2004  NOTICE: -->Python Interpreter Initialized<--
20:08:49 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:08:50 T:4172  NOTICE: Thread LanguageInvoker start, auto delete: false
20:08:50 T:4172  NOTICE: -->Python Interpreter Initialized<--
20:08:50 T:3544 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(image) in image://http%3a%2f%2f192.168.7.99%3a8096%2fmediabrowser%2fItems%2f1032c77f74521bb54c4739aaf5aaae4a%2fImages%2fBackdrop%2f0%3fMaxWidth%3d10000%26MaxHeight%3d10000%26Format%3doriginal%26Tag%3de3ab56fe27d389446754d0fb04910a34/
20:08:51 T:3868  NOTICE: Thread FileCache start, auto delete: false
20:08:51 T:796  NOTICE: Previous line repeats 1 times.
20:08:51 T:796 WARNING: XFILE::CDirectoryFactory::Create - unsupported protocol(image) in image://http%3a%2f%2f192.168.7.99%3a8096%2fmediabrowser%2fItems%2fd36e0266809f7b2d0824a9847bb878ca%2fImages%2fBackdrop%2f0%3fMaxWidth%3d10000%26MaxHeight%3d10000%26Format%3doriginal%26Tag%3de3ab56fe27d389446754d0fb04910a34/
20:08:51 T:5084  NOTICE: Thread FileCache start, auto delete: false
20:09:00 T:4852  NOTICE: Previous line repeats 3 times.
20:09:00 T:4852  NOTICE: emby WebSocketThread -> Log Level:1
20:09:02 T:4652  NOTICE: CDVDPlayer::CloseFile()
20:09:02 T:4652  NOTICE: DVDPlayer: waiting for threads to exit
I had the same issue with pixelation and artifacts on one of my machines a while back. On that particular one I use the integrated HD4600 graphics on a Core i5, in my case it turned out to be a driver issue which was eventually solved after a seemingly endless wait for bugfixed graphics drivers.
It is fixed with the WIP DirectX 11 build. So it seems to be an issue with Kodi, DX11 and drivers.
Before testing the WIP build I reverted AMD graphics drive bit to no avail.
