2015-03-07, 15:37
Hope someone can help me out here ? I got a New MX Android TV Box Dual Core Smart XBMC Fully Loaded which came the other day there seems to be a problem as the tv screen keeps on flashing every30 secs or so and will not stabilise and its driving me round the bend I have been in contact with e seller and his reply was
"1.Inserted your SD card into PC. 2. Copy five update files to your sd card. 3.Now insert your sd card into your Box. 4.use a pin press the recovery key through the AV socket , 4.then pulg your AC power, and wait for the update done. PS: Pressing the recovery key must keep for seconds." I do not have an sd card and I no thing about where too start surely the box would have been tested out before it was dispatched.
I also asked for a full refund due to faulty goods and that was his answer I do not want to do what he says as for then surely that would void the warranty
Many thanks in advance
regards
sky- hunter
p.s mods if this in the wrong place please excuse my ignorance and please move if needed
regards
sky- hunter
